work in progress , my manco quicksilver 2
Half-breeder
"Edit" button removed
Im alil curious as to why the wheel are turning at 'idle' on both of the karts... (especially the one w/ the ducar)?
RPM's kinda high maybe?
firemanjim
Just kartin' around....
Houston Texas
Thanks Sam! That's what I was wanting to know..... ! :wai:
I like the dingo.....
A solid chain is a chain with no master link. You can make it the old fashioned way with a hammer and punch. OR the easy way and buy/use a chain breaker tool to make one. Instead of master link, you connect the ends with a normal link. On a master link, you can pull one of the side plates off by hand. You can't do that with a normal link. When it's pressed into place, it stays put. You will literally have to break the chain, not just a weak ARSe master link..... :thumbsup:
therealsamfisher
same here lmao. they dont drive away when on the ground , but whenever I bring them up they do that.
ill have to look into that , i WILL break this link again..
gman3850
gilbert az
I just put a 420 chain on today instead of the 41 with master link. did a lot of burnout and donuts in the mud, street, and grass also ran over the curb and my chain is still holding up.
therealsamfisher
so how the engine is aligned now ( which is perfect , not the same as this photo where it was a little off ) the exhaust points at the frame , which makes it impossible to use the screw in silencer which I reallllly need to start using lol.
should I try heat and bend , or cut and weld?
firemanjim
Houston Texas
No heat, just remove it. Find something with a hole big enough for the tube to slide into. Slide it in to the point where you want the bend(un bend) . Now gently pull on it, slowly bending it the direction you need/want. Move its position in the hole 1/4" at a time. Do little bends and you won't crease or mar the tube..... I do it all the time to correct bent angles when I'm building..... 1" tubing fits into the hole for a ball on your truck/suv bumper..... :thumbsup:
therealsamfisher
gonna try this now , before it was re-ailigned , the silencer fit and my god was it quiet.. but did not feel restricted either even after womping on it for a bit.
I lost another breather though... it just wont stay no matter what. I will have to make some sort of bracket for it .
on another note , cleared out a car for more go kart funz lol
potato pic
therealsamfisher
well... I tried bending that pipe... ended up sledging it flat since its godly materials wanted to test my resolve.
therealsamfisher
ok , so I tweaked the rear engine " frame " cage that bolts on to the back
now I dont have a bar in the way!
also , will be posting the video of why it was tweaked lol , got a lil out of control last night lol
therealsamfisher
welll... I crashed again lol....
flipped her good this time.. kart was mid drift and again wanted to grab so it rolled right onto me.
I have neither been more injured nor more entertained at the same time in years! this is amazing!
Half-breeder
