P.S. i know, the garage is a dump![]()
If the transmission spins too fast it strips gears and ruins the bushes, but if you gear the output shaft it puts a lot more stress on the box and you can strip gears, and split the case.
Not very suited for gokarts, even quite low speed ones
Good luck with the build.
the idea is to use the stock drive system (i.e. the same gear ratios, pulley sizes, etc..)
the only differince is the drive belt will be shorter.
lake effect
