well, it looks better on the last pics you posted, still I don't think the driver/driven are perfectly aligned (inside of the inner sheave should be 100% parallel and in line)
Anyways.. sticky driver.. remove the bolt and top washer, and the bell, shoes, inner sheave..
basically everything until you have to remove the belt.
Inside there's a clover-shaped hub, make sure that said hub is clean and has no burs whatsoever!
it has to drop right through the inner sheave on it's own weight, barely (so there's no wiggle room) but it has to drop.
If that's the case, and the sheaves are indeed perfectly aligned (if you have, test with a line laser tool)
it's the belt I'm afraid.. maybe the TC was swapped on the way, IDK why a trailmaster would use a non std belt if it's a std comet TC...
So, reinstall the driver clutch parts, and measure the center distance driver bold, driven shaft.
should be 6 5/8" to 6 11/16", if not report back..
if it is, make sure that the outer circumference of your belt is 27" exactly.
(if it's too short it'll lock up)
if the black screw does NOT set your idle speed, your throttle cable does not allow the butterfly to close properly.
so, release either the engine or pedal side and readjust the throttle cable, so that it does
