Scratch built buggy question
Dennyjr319
My daughter mini buggy has a predator 212 stock. 18 inch atv tires 6-1 gear ratio with tq. You think that's a low enough gear ratio to do some small hillsImageUploadedByTapatalk1414631444.756810.jpg
Just that guy
Zombient
Junkyard Derelict
Waco, Texas
I"m no pro, but that thing does look heavy.
But since you're using a torque converter, I'd think it would work.
But again, I'm no pro.
Dennyjr319
Yeah we had it out last weeked with 4.8-1 and it was horrible so if it don't work with 6-1 I'll go with 60 and 8 on torque converter
Just that guy
Half-breeder
"Edit" button removed
IMO I would say that it might struggle a little with 18" tyres and 6:1 gearing, but the best way to find out is to ride it and see.
It 'does' look like a heavy frame... so :iagree:
If you keep the 6:1 you may hit about 30mph (w/ governor intact). My kart (previously, pushing 450lbs) was able to hit topspeed w/ a TAV2 w/ a 5:1 on 16"s... but it took a ways to get to topspeed (avg 42-45mph... top 50mph).
If you are looking to possibly be able to break traction on pavement I recommend for you to think bout a 7:1 (topspeed 28-30mph). If that's all youre looking to do is kick up dirt and lay rubber... Id go to a 8:1 or greater. But that is all just IMHO... from experiences.
Yeah we had it out last weeked with 4.8-1 and it was horrible so if it don't work with 6-1 I'll go with 60 and 8 on torque converter.
Sounds like a plan... but just curious... what chain # are you runnin and where are you getting a 8T TAV replacement...?
Dennyjr319
41 I just got a 5/8 keyed 8tooth sprocket and we want it to be able to stop on a hill and take off again speed is not really a big deal cause. We mainly just trail ride in our full size buggys ImageUploadedByTapatalk1414666066.269861.jpg
Just that guy
tazmannusa
Yettem, California
My daughter mini buggy has a predator 212 stock. 18 inch atv tires 6-1 gear ratio with tq. You think that's a low enough gear ratio to do some small hillsView attachment 53183
Just that guy
I guess it would depend on what you consider small hills? steep or rolling. when I had the 212 with tq on mine with 18" tires I ran a 7.5:1 ratio and it worked out good climbing steep short hills .
I did try it with 6:1 and it worked but I had to get a run at the hills . I weigh in at about 200lbs , if your daughter is light weight 6:1 will probably be fine
Half-breeder
41 I just got a 5/8 keyed 8tooth sprocket and we want it to be able to stop on a hill and take off again speed is not really a big deal cause. We mainly just trail ride in our full size buggys View attachment 53194
Just that guy
... didnt know there was a 8T #41 for a 5/8" shaft.. hmmm.
7.5:1 on 18s should work well for trail runs... but again... weight is a deciding factor... if you start eating belts... may wanna reevaluate the ratio again.
IMO, if topspeed wasnt an issue, and offroad trails/hills was the terrain... and if 7.5:1 dont work for you... Id dare say try a 8.5:1 or even 9:1. Much more n you hit topspeed in 5ft... w/ a slightly sore neck.
Also, remember... the 30 series has the 3 driven settings... if you are wanting to imitate a 2wd rock-crawler... setting #3 is the probably a good setting to set up for.
https://www.youtube.com/watch?v=kmGY0qsgW4Y&list=UU9tLeV67lsEIrulgHA6t0wg
Dennyjr319
Yes I have just switch my tc to setting 3. I think I'll just try the 7.5-1 first I already ordered the sprocket. And yeah mainly short steep hill she will be climbing. She and her buggy aren't ready for the big coal hills out here yet
Just that guy
Half-breeder
... which brings me/us to the next order of free business participation...
Around here, it is proper etiquette to fill out ones profile(mainly location), for future locational help. Plz fill out your profile, as best as you can/will. I hear 'coal hills' I tend to think WV... but its unknown, due to no profile registry... :thumbsup:
:backtotopic:
