new guy question
jayjay
Hi folks i purchased a DRIFTA KART 6.5hp 19mm shaft with centrifugal clutch 10teeth and the rear sprocket i think is 50teeth
the tyres are 13-5.00-6.00 same sie as a 50cc quad bike.
so wanting more height i replaced the wheels same 6"rim but a higher and wider tyre(145/70)same size as a 110-125cc quad bike they look 10-15mm larger than the original wheel tyre.
will this have to much effect on the ratio?
:huh:
This will affect your gear ratio. It will be as if you had geared higher. I have a feeling that your kart might struggle a bit, as it was already geared at 5:1
The only test is to actually ride the kart. If you feel sluggish and the clutch bell gets too hot or smokes, then you will have to maybe get a 60T rear sprocket
jayjay
thanks for the answer i dont think i could get a rear sprocket of that sizeumm i forget what its called bolts on the side of engine torque convertor or similar would this work
cheers
cheers
Jackshaft?? I am not too sure what you are talking about. post some pics of your setup for us. Why do you say you cannot get a 60T sprocket. You should have enough clearance
jayjay
Ok i was just looking on internet thanks again is there any pics about on forum thats been installed already
