gasket replacement
fanderson
connecticut
Hi everyone,
I was taking apart my 212 predator engine this afternoon (cause why not?:thumbsup:) and I noticed the gasket on my intake port was no longer 1 piece. Do I need to buy a factory replacement for this? If so where would I be able to find one? Thanks
firemanjim
Just kartin' around....
Houston Texas
I make all my own replacement gaskets with FelPro gasket paper, available at your local auto parts. Just trace the old one onto the new paper, and cut it out..... :thumbsup:
You will have enough material to make many gaskets,of all shapes and sizes..... And a roll of gasket material is fairly cheap.....
fanderson
connecticut
I also noticed that the plastic peice (circled in red) on the other side of the gasket has a slightly smaller opening than the one on the intake port (circled in yellow). Could I drill it out to increase the flow? Would it even make a difference?
supermanotorious
Winchmaster 5000
New River, AZ
you can also get virtually any replacement part from Harbor Freight, I've done it 100 times, I am currently waiting for replacement head band/strap assemblies for my HF welding helmet, I've ordered tons of replacement case gaskets from them for all the governors I've removed, usually parts orders from them are really cost effective, just look up the manual on their site and go the parts list/ exploded diagram
zbuck
Ft. Wayne, IN
:wai: Something is wrong. The head has a D shaped port and that plastic piece is round shaped. Therefore screwing/restricting up the flow. If it were me, I would alter the plastic piece to have the same D port shape as the head.
They might be doing that to keep air speed up (velocity) through the carb and lower the power band to a more usable range. You might kill your low end torque though.
Isnt that spacer d shaped on one side and round on the other? In other words, it transitions the two?
Yes, it is; look closely & you can see the shape change; it's made that way so that one side matches the carb & the other side matched the port; DON'T CHANGE IT, just put it back on as it is...
