brake systems
blackshuck
I cant seem to find any custome brake system ideas, im want to making a brake with a disc and pads. Are there any known links anyone could share that would help?
That a pretty vague statement. How custom, we talking handmade caliper banks, or bracketry?
I made a bracket for my bike's rear brake....
Half-breeder
"Edit" button removed
Well, there's hydrolic and mechanical disk brake setups for 'custom' fabs...
Depending on the total weight/size of the kart... if its a reasonably smaller kart<350lbs... a mechanical disk setup will work IMO...
This is what I did to 'custom' fit one on mine... yes... those are bed rails that I used for the bracketry...
You can buy a disc brake kit, with disc and pads, for around $170 US.....
http://www.gokartsupply.com/discbr.htm
Or piece one together......
...or find a cheap Chinese hydraulic setup for around $50
"Custom" implies made for a specific vehicle or purpose & can include anything from mounting hardware to the caliper, you need to be a lot more specific as to what you want...
blackshuck
perfect man thanks a bunch
Half-breeder
Guess I gave him what he was looking for.. :thumbsup:
...again proof of the ole saying... "A picture is worth 1,000 words."
... then again... could be looked at as "It's not what you say... but the way they are said..."
Looking again at those pics... :ack2:... glad I painted em!:rolleyes:
Blackshuck... remember the key to the brakes framework is vertical and lateral (forward/backwards) stability more so than horizontal. Youll want to ensure that the shoes of the caliper completely contact the disk surface... and the cable connection (where the hole for the cable is drilled) should be 90* from the end of the arm, at full braking, for fullest leverage to the arm. It is also possible to lengthen the arm some to attain increased leverage/added braking power... however the cable connection would have to be moved coincidingly.
Ensure clearance measurements... I didnt... and if you look, you can see I was off by 1/4"... the brake caliper mounting bolt head is setting "IN" the cooling shroud's intake vent/starting cord's mount. I had to grind out a section to 'fit' the engine... vs cutting rewelding.
There are other things to mind for when fabricating a disk brake system to your kart... Ill let others reply instead of you reading my notoriously long explanations that are hit/miss on accuacy.
