nixta
I took advise and lapped my valves indexd my sparkplug.checked my cam dots lined up set valve lash to what the cam card says motor only runs on choke dies when choke is switched off any ideas guys
LEDGEND IF WE EVER MEET I.O.U.A BE OR TWONo... dont think its the springs... more probably the fuel/air fixure... should be a copper screw on the side to adjust (may have a limiter cap on it, which will need to be removed). Im not positive if your carb has the screw im speaking of... but... #5
it's broken off for a reason
that's a snap screw it's supposed to be set once and then broken off by the service personell.
it's brass and as such soft, small reverse drill bit and you can remove it;
and replace it by a settable or 'new' snap off screw
no that looks more like a screwdriver mishap I'd say
