Yep, the float should seal completely, even at a few psi. Generally speaking, carbs can hold a good bit of gas more than they're supposed to before they start leaking, this is likely why you thought it was working okay when you used a standard tee rather than the check valve tee -- it was filling up, it just takes a long time to get full and start dripping. If you want to confirm this, you can either wait and keep topping up the fuel line to maintain pressure if necessary, or drain and measure the contents.
From my experience with motorcycles, OEM needles lasted much, much longer than K&L brand... I imagine the same would be true for karts from a reputable brand.
Also, not sure how those carbs are built up, but if it has a removable float seat it could be an issue with the seal between the seat and the body rather than between the needle and seat.
Replaced float seat, o-ring and valve. Pressure tested carb inlet hose to 4 psi. It still had a slow leak - took 14 minutes to leak down to 3 psi. Removed cleaned with Q tips and metal polish. Retested with gas line hooked up to fuel inlet. After 30 minutes it went down 2 inches. Keep in mind the original seat and float valve lost 4 psi in about 3 minutes and dropped 12 inches in 30 minutes of fuel test, so much better. Unfortunately after running a few minutes overflow fuel leak reappeared. Tore carb back down multiple time to recheck floats, height, ETC!!! but no luck. Does anyone have a good source for OEM original float seats and valves for a FL250 Honda Odyssey. The original seats have 2 holes and the ones off Ebay have 4 with smaller needles? I tried to see if leak was coming from seat or needle but being so close, I had no luck. You guys have been great and I'll keep plugging away
Thanks again, Marty.
Love your Odyssey rebuilds. Badot has been a huge help to me but feel free to chime in. Rebuilt carb with all OEM parts and boy what a difference
