Question about 8hp Briggs
Zombient
Junkyard Derelict
Waco, Texas
I'm sorry if this has already been asked before, I didn't see it in the long list haha.
I have an 1974 8hp Briggs that I'm planning on fixing up and putting on my go-kart. I like the year because it look fits the whole theme of the go-kart I'm building.
My question is, what aftermarket parts are there for 8hp Briggs, if any? I've seen plenty for 5hp but nothing so far for the 8hp. I could just be looking in the wrong places.
Also, what performance mods can I do to this engine, other than polishing the ports and shaving the head?
Lastly, the engine itself has a sticker on the shroud.
"Phoenix Fun Machines." I have no idea if that was the brand of Go-Kart it came off of or what. I'll have pictures later.
Thank you!
firemanjim
Just kartin' around....
Houston Texas
You can turn your 8horse into a 12+hp giant, for just a few bucks and a few hours. Change the intake and exhaust to a higher flow set up. Open your main jet, just a tad..... Then take out the governor. You're looking at a 12 horse power house...... Or more.... Depends on how far you want to go with it. 8-12 hp on a kart is plenty......
2SlickNick
American Minibikes @ FB
Mesa, AZ.
As far as I know.... The mods Jim mentioned is all there is.
Like you stated, I too have seen plenty if aftermarket upgrades for the 5hp, but none for 8hp. Unless billet connecting rods and flywheels cross over.
Zombient
Junkyard Derelict
Waco, Texas
I think I can do the exhaust without any problem, but how would I go about doing a higher flow setup for the carb? Would a 10 or 12 horse carb work? It has a float carb on it now, although I'd rather just use a different carb. I've read about using 2 cycle carbs on a Briggs, but I've never played around with it, nor do I even know what 2 cycle carb would fit.
From what I've heard, float carbs are not that great on go-karts because the gas is slinging around in the bowl. I could be mistaken.
firemanjim
Houston Texas
High flow intake is simple..... Free flow air filter, mounted to your carb.... Take your carb off, open it up, then call me......
Ok, ready? Pull out the main jet. You want to open that little hole in there, just a tad... If you have can get a welders tip cleaner tool, you can use that to resize the jet. It's how I do it. Find the rod that fits in the current hole. Then slide it back and forth, and it will slowly open the hole. Do this until the next size rod goes in. Just try one step first, then run it and take a plug reading to see if your lean/spot on/ rich...... ,if yours has an emulsion tube too, open up the holes for more fuel flow.....
There is not NEED to get a different carb...... BUT you can if you want. On a 8hp engine, you could probably adapt a pz26 carb to fit it and function properly. I gotta look at what engine you have..... I might know some options for you.....
Zombient
Junkyard Derelict
Waco, Texas
Sounds good. I'll try and get some more pictures and a model number. I'll post them here ASAP.
