New to Karting - Build project
PsionicWiz
Hello all. I'm looking for all you experts out there
Engine - Honda 5.5 clone
Frame will be built from 1" square tubing (is this big enough?), will start with road slicks 5 or 6" wheels. MY goal is to build a racer type kart.
I would like to keep this to a small budget however I want this to be a quality build
Im looking for drive train setup
What is the difference between a live and dead axel? whats best?
  • Size of axel? 1" or 1 1/4"? Tubular? or solid?
  • sprockets?
  • Chain?
  • what clutch to buy? best bang for buck?
  • Axel bearing?
  • Hubs? (seen some with and without, not sure the difference or whats better)
  • Axel Bearing and carriers?
  • Wheels -
  • Disk brakes (should I use the kind that mounts on axel or the disks that require a hub of sorts?
Front wheel/steering setup
  • spindle setup?
  • Hubs?
  • Wheels
firemanjim
Just kartin' around....
Houston Texas
:welcome2:
Well, where to start.....
Yes,no,yes,yes,maybe,yes.... :lolgoku: j/k.....
1"square tube 16gauge is fine. Live axle or dead? That's kinda a personal thing. I prefer a 1"solid live axle. But i have the most fun driving my daughters 2 seater with a dead axle. For a simple "street racer" kart on a budget, go with a dead axle. You can do a live axle on the second build..... :thumbsup:
Max torque or comet clutch will work, about $30-40. Chain,#35 should be sufficient, but buy a name brand chain. Sprockets? We will get to that after you get some wheels and tires. If you want your typical kart slick, go with a 4.10/3.50 on a 4"-5"or6" wheel.... Then we will do the sprockets.... All your wheels will be bearing hubs. The drive wheel will have a double flange allowing you to bolt on the sprocket and a band brake. A band brake, set up properly, is sufficient at stopping your average kart. Generic manco spindles and brackets.....
What did I miss? ....
PsionicWiz
:welcome2:
Thanks Jim,
So what is the difference between Live and Dead axel? and benefits?
any recommendation for disk brake setup, I live more for the buy once and your good... I may plan to upgrade the engine later (probably will) may even go into a shifter eventually. (i will then consider front brakes as well) :)
firemanjim
Houston Texas
On a live axle set up, both tires are driven by the engine via the full length axle. On a dead axle set up, only one wheel gets the drive. They both have their places. A dead axle is real responsive when playing on the street, but lacks traction if you venture onto the grass or dirt.
A live axle gives great traction, but makes simple turns on the street a hassle.
This is where it comes to personal choice. Each one has its own benefits and flaws. You just have to decide which is best for your application. :thumbsup:
PsionicWiz
Next steps
Ok I have the frame measure cut and tacked. Tires came in today.
The tires are 4.5/10.0-5 Fronts and 6.0/11.0-5 rears - American bolt pattern
Looking for your advise and recommendation on the rear axel setup some of the things that I'm unsure of....
what type of axel should I go with?
Tube or solid - what is better and why?
Here what I was looking at getting....
http://www.bmikarts.com/1-14-Tubular-Steel-Axle-14-Wall_p_510.html
Axel Bearing?
Im looking at this kit but will be adding a 3rd
http://www.bmikarts.com/1-14-Bearing-Kit-3-hole-_p_485.html
Would these hubs work for my application?
http://www.bmikarts.com/Lightened-Aluminum-Racing-Wheel-Hub-Set-Front-and-1-14-Rear_p_2440.html
Axel locking collars?
How many will I need and what would you recommend?
Sprocket hub and sprocket?
Any recommendation here?
Brake hub and rotor
Front spindles
Recommendations?
This will also tie into the next step as well, What sprocket and clutch should I go with my application?
and brake hubs.
I know these are alot of questions I just dont want to make any mistakes here and get it right the first time. and considering that I am ordering all the parts from the states I prefer to make one order and have everything. Id hate to miss a few items and have my build delayed another few weeks.
firemanjim
Houston Texas
Off the top of my head, I'd say run a 5.4:1......
Do you know why that chassis is designed the way it is? Are you copying another race kart?
The reason I ask is cause you're asking pretty simple questions, but building a complex, flexing, race chassis.....
PsionicWiz
I am indeed new to karting, in fact this is my first build. Other than going to the local kart track ive done nothing.
Ive done my research on frame design and what I was looking for. To be honest I looked at many designs and incorporated bits and pieces here and there. I just didnt want to build a plain square box and add wheels to it....hence my design. Considering that Im doing everything myself I saved some $, but would like to take it to a local track for a fun day.
http://www.bmikarts.com/1-14-Tubular...all_p_510.html
Axel Bearing?
http://www.bmikarts.com/1-14-Bearing...le-_p_485.html
http://www.bmikarts.com/Lightened-Al...ar_p_2440.html
Front spindles
Recommendations?
Two out of three ain't bad...
The axle & wheel hubs you've selected should be ok but, then you go & select the cheapest bearing setup you can find :huh: Personally, I think you're better off with cassette type bearings...
As for locking collars, if you use the correct hubs, you shouldn't need any; I have 3 karts & not one locking collar...
For spindles, I suggest something like these
