Briggs 5hp cheap upgrades
williamb31
I just bought a go kart with a 5hp briggs and Stratton engine, ignition coil wasnt working but just ordered a new one. For the trails I'm riding I'm gonna need more torque, what I'm already planning on doing is taking sand paper and polishing the intake and exhaust ports and also the eyebrows with a slim copper gasket for the cylinder head to increase compression. Then I'm gonna put a free flow air filter and a straight pipe then take off the govener, since I'm increasing the flow of air shouldn't I increase the flow of gas? If so should I get a new carb and which one. I've also looked at changing out billet rods and internal stuff but it seems once you change one thing out you need to completely rebuild the engine to hold up all the power. Just looking for advice on what to do, thanks!
RiverSideRun
NJ
Straight pipes are so loud.(I learned this the hard way)
If your running on trails a torque converter will allow you to maximize your torque
You will need to re-jet your carb so it won't run to lean.
Here is a link to teach you how: http://www.affordablegokarts.com/Drilling Main Jets.php
Hope this helps!
Well. ....not necessarily. .....
A lot of advice bouncing off the walls here from a lot of new members. ....not saying you guys don't know what you're doing. ...but there's some pretty sharp guys here....and you might be better served to slow down a bit. ....
So....first off....what we like to do. ....is figure out exactly what engine we are dealing with before giving out advice. ....
You linked to a different engine and a different carb. ....
Next.....no one here can say whether he needs to re-jet or not. ...
But as alluded to in the link....a spark plug reading can.....
Often times these Briggs run somewhat rich out of the box....so coupled with the fact that we don't know how much better this engine will breathe ....
So one thing at a time. .......
williamb31
So depending on how it runs will say if I should adjust the carb or not, and I heard of other people polishing out the ports and eyebrows but I don't know exactly how to do it lol does anybody have any idea how to do this?
rmm727
Brookville, PA
I would just remove the governor and be done with it. Side cover and a throttle kit. $15-20 tops. Anymore, I dont mess with the 5hp flattys. Clones are cheap and plentiful and make more HP per dollar. Some worry about reliability but if you keep the oil changed and know when to let off the throttle they are just fine.
HighTechRedneck
#01 Go Karter
Drayton, SC
You are right... He might not have a mikuni type carb. Sorry for posting advice so quickly without doing close research, I will make sure to do better now on.
Thanks for correcting me!:oops:
Yes, quite a few of us do & here's what I think: If you have to ask how to because you don't know what you're doing, DON'T DO IT! For starters, it's MUCH more involved than just
It's a delicate process involving power tools (you'll be there for weeks with "just sand paper") where one stroke can mean the difference between a brilliant engine & scrap metal... (slight exaggeration but, you get the idea)
What experience do you have?
