apekillman
hi, new to the forum. very nice site. thank you everyone that contributes to make it so great.
I've recently had the chance to buy a 2 seater manco kart. perhaps a dingo? it ran when i bought it but blew smoke. i tried to do some carb TLC with no good luck. so i bought the infamous harbor freight predator engine. seems to be working fine. anyway, i want to change a few things around. it had big lawn tractor wheels on the back and the guy swapped them for ones a little smaller. and it had some solid hard rubber tires up front that were really bad. i bought some cheap harbor freight ones for the interim. what i want to do is get some decent wheels and tires both up front and in the rear. i was thinking about 4 inch up front and 6 inch in the rear. one question i have about that set up is would i have to worry about the gear ratio? right now its running a 12 (from a jack shaft(?)) to a 72 tooth on the axle. also, I'm worried about clearance for the chain wheel once i was to get smaller wheels. also, when i am turning at speed, the front mostly just plows forward while the tires just get pushed sideways. i realize that those HF tires are super cheaply made, but would this also happen with better quality wheels / tires? do i need to check the ackermann and all that stuff? thanks foray and all advice on this matter! gonna try to post a few pics of said kart right now.....
