Magneto rubbing
RiverSideRun
NJ
The magneto on my 5 hp Briggs and Stratton rubs slightly on the flywheel for about an 8th of a full revolution.
No big deal?
If not how do i fix
RiverSideRun
NJ
Would it be wrong to sand the flywheel ooorrrrr unbolt the magneto and see if there is any play in the mounting
Or do it the poboy way
Axx3d
MN
Id dissemble,clean and reset the magneto. No need to hit it with anything yet.
Russ2251
AZUSA:Powered by LAWN-BOY
If your going to stay with the hobby, get yourself a good set of feeler gauges.
Is that what they are supposed to look like ??????? Mine are brown....lol....
The thing about setting the magneto with feeler guages is that is supposed to put the magnets at that distance. .....
They may already be there.....and the spot that's rubbing. ....not. .....
So. ....check that first. ...if it's rubbing away from the magnets the best you can do is adjust the magneto to where it barely clears that spot.....
Russ2251
If this indeed is the case you'll be needing a new flywheel or bearings or crankshaft or all three.
Let's be professional about this. Use the feeler gauge with magnets under magneto/coil. If after making this adjustment mag still rubs anywhere...check for other probs such as run-out.
Do not run engine until this is sorted out.
It is very unlikely that there is any problem at all.
