Chain Problem
thaipham25
texas
I see a tension spring on your idler, yet the chain is on the front of the idler wheel. How does that work?
When the sprocket pushes the tensioner down the spring pulls it back up into place so it won't get over tighten. If it does u lose hp supposedly
Sent from my LGL35G using Tapatalk 2
I'm defiantly going to say... IBTL on this one....
I reckon you too Thai, as this may almost be your last post with that last one...
So..
Cameron, I think we need a pic of your engine mount (underside would be great as well)
maybe zbuck's welded on nuts will be the way to go, maybe we can see a simpler approach to keep the chain tight.
BirdFanatic
Jonesboro Arkansas
ok i have a spare mount ill take a pic of there the same thing
yes my garage is dirty but its my only messy place :) every man has to have one place to make a mess
Oh.. uhm... how do I say that...
No, that is a different engine mount that might be similar, but it's not the one we would want pictures of.
The importance here isn't only the actual mount, but it's connection to both the frame and the engine; it's exact locatio the condition of the frame etc.pp.
So.. we need pictures of THE engine mount, not A engine mount ;)
