Another 13hp question
yancy_tant
Hey ya'll new here im sure its been posted but i got a 13hp honda motor off a generator, Converted it over to a 1'' shaft and gotta figure out all this gearing situation. dont wanna spend anymore than 200 on a clutch. i dont want a torq convert as im not off roading or low-speed/stop and go type riding and what not. I read somewhere someone had theres up to 70 so thats about where i wanna be strictly speed. adult driven the rear is set up where both tires spins so dont know where to go on with a jack shaft. Thanks!
firemanjim
Just kartin' around....
Houston Texas
:roflol::roflol::roflol::funnypost:
Is someone gonna help this dude?
Yancy, how did you convert a 1" shaft to a 1" shaft? I'm stuck on that one.....
Sorry man, you're not gonna get 70mph on that thing. Not safely anyway..... 70 on a kart feels like 100..... 40-45 mph feels like 70..... Let's try that first, before you kill yourself.
That's a yard kart, NOT a race kart. Gotta get that straight. It was NOT designed to go that fast.
With a 13 hp engine, no, you don't have to have a TC. Try looking at Noram clutches or Hilliard inferno clutches.....
Gear ratio? Need to know the size of your tires. Need to know how many teeth are on your clutch. Need to know how many teeth on the axle....
There is a lot to learn about going fast...... Out of curiosity, how old are you and what kind of fab skills do you have? If you can't weld, then I'm done..... :surrender:
kart bruiser
Leechburg,PA
that torque converter is not for stop and go it for allowing you to have 110% of torque put out by your motor and at same time giving you an unlimited top speed { only limited by motor output}
you definitely would need larger mounting plate for larger base
you can figure out how to get it on there
i suggest welding
as for jackshaft they are easily fabbed out of pillow blocks and 5/8ths cold rolled steel
you should be able to mock up engine and jackshaft with gears all lined up with tire able to stay in stock position
mine in this pic is not bolted or chained just getting positioning
wheels were moved in to tighten up look in the end
get that old mount plate grinded of and new plate mounted more to right for gear room and we will go from there
good call on welding FJ
if you cant find someone who can ???
kart bruiser
Leechburg,PA
i think he meant he converted a 1 inch tapered generator shaft to a straight 1 inch normal shaft alot of work
kudos if thats what you did too
just let me know if i can now eat my shoe?:lolgoku:
for giving benefit of doubt
i am new here does that count still?
OMG......
Yeah. ...............this is the cyber world.....where idiots can appear as geniuses. ....and vice versa. ....
But.........whoooooooo.......
Anyways. .....here's what ya gotta git did.....iffin youall il jest walk about 2 blocks southway.....youall see Saudiarabbiya Clutch Shop on your left side..
Go in and ask for Mr. Phelps......maybe he can help. ..
davidbooth1991
Nottingham UK
I got offered a gx390 for £80. ( the power side of the Genny needed a voltage regulator..) But when he took it out the shaft was strate but not keyed...
yancy_tant
Yeah converted from tapered to straight. And maybeeeee I was just in the moment when I heard 70 lol but I'm 25 and it's just something me and my buddies are gonna play around with at our shop and yes I do welding and machining for a living just not sure how to get the most out of this engine so which ever is better torque or clutch I'll go with lol that's what I came to you guys for haha. So far only got 60 bucks in everything and by no means complaining ;)
firemanjim
Houston Texas
O! Well see, that's a different story...... You're not a "dumb kid".....:lolgoku: (no offense, children. I was a dumb kid too. )
Ok Yancy, tell us what size tires you're going to use. I can help you figure it all out, but I need more information from you, as asked earlier. And it would be extremely helpful to post some pics of what you got.
I'll be back..... :thumbsup:
MancoGX390
Just tinkering...
Devon, England
Yancy, i have a GX390 honda with a bolt on kit added to it running through a comet 40 series torque converter, even though torque converters are expensive they are well worth the money and in my opinion, way better than any centrifugal clutch will ever be! so if your going all out on a nice engine, do it a favor and get it a nice drive system! I also recommend a 9 tooth jackshaft sprocket to a 54 tooth axle sprocket for a perfect 6:1 gear ratio.
rockman96
SC
I hate to thread jack, but you need to beef up your axle supports if you're putting that big block on that chassis. You'll tear 'em off your frame if you don't (and probably leave holes where the welds were.)
MancoGX390
Just tinkering...
Devon, England
Wait rockman are you talking to Yancy or me?
carter
You could go steeper than a 6:1 if a bit more top speed is what you're after. On my cart I have a comet 500 series with the 7 1/2 inch driven and a 5.5:1 JS on 18' wheels. It's ridiculously fast in terms of top speed and pulls it's way up to it pretty quickly too.
Mind you on my cart I have an HM100, which is less powerful than that GX390, being 40cc's smaller and a flathead. You could expect to see better performance out of the same setup.
MancoGX390
Just tinkering...
Devon, England
I decided to stick with a 6:1 ratio because im pushing 22 inch wheels so if i went a bit higher it might just be a bit to high so I've stuck at 6:1
carter
ah, with 22s 6:1 is probably the safer bet, didn't notice your wheels were that much bigger than mine. You probably see a bit higher of a top speed than I do actually though, If I recall the 40 series drivers are smaller than the 500 series drivers.
MancoGX390
Just tinkering...
Devon, England
Im not sure to be ohnest! It may be a little bigger like half and inch on the clutch and the pulley, ill check that out and ill edit this with the accurate sizes
EDIT: The 500 series driver clutch is 5-3/8" and the 40 series driver clutch is 5-17/38". The 500s pulley is 7-1/2" and the 40s is 7-1/2" aswell so they are roughly the same size
carter
is the comet 40 7 1/2? For some reason I was thinking they came in like 6 and 7.
Clifton
Illinois
I believe it is as follows:
20/30 series - 6" or 7"
40 series - 7 1/2"
44 series - 8 1/2"
500 series - 7 1/2"
858 series - 8 1/2"
From looking at various comet manuals.
