Tecumseh Valve Springs
carter
36lb springs!?? Your joking, right? :surrender:
agreed, why don't you try on 18lb for size, that should get you like 7k. or even 24lb which could see you up to 10k. Unless you have a billet flywheel and conrod, you need to steer clear of ANY spring upgrades.
TecumsehBuilderJDKirk
JDKirkPerformanceEngines
Onancock, Va
If you run the 18lb use the 33158 cast iron camshaft hard to find but you canget them on ebay for about 25$. Going to try the nylon camshaft with these I will let you know what happens.
