Which motor do I go with
Tanner9690
Tempe Az. USA
Hello there I am building a custom offer a go cart and I was wondering what kind of engine should I use. I have an option for 18 hp Honda industrial engine or should I buy like a 2stroke bike motor. My ultimate goal with this project is to be able to go trail riding which engine or what kind of engine would give me my best results with having to do minimal set up will work to the engine itself
trail means off road..right?...
that means controlled power (slow but with enough torque to climb out of a mud hole)
Soooo no two stroke I'd say..
those are great, don't get me wrong, but they need rpms to provide their power;
I'd go with a four stroke (that'd be the Honda industrial engine)
:iagree:
A 4 stroke bike or ATV engine will also work well as you have the option of multiple gears...
Speaking of multiples, please don't create multiple threads asking the same question...
Tanner9690
Tempe Az. USA
Ok sorry I'm using my I phone and it wasn't showing this thread posted. I kinda want to go with an automatic engine. I'm not a fan of Changing gears. At least for this project. But I want it to sound sick. Can you put something like a exhaust kit on an industrial motor?? And what size industrial motor should I get I weigh 200lbs and the frame for my kart is about 125lbs. Also since I will be trail riding do you recommend a torc converter or centrifugal clutch. I found a centrifugal clutch for $115 rated up to 40 hp. And I don't know anything about torc converters
rushking19
Richmond Virginia
First we need to see some pictures of your go kart, and you can fabric any Type of muffler you want for it
Tanner9690
Tempe Az. USA
I'm in the process of fabricating it up I bought plans from badlandbuggy.com for it I just need to fab it. The plans can fit up to a 26hp industrial motor I am trying to get my ducks in a row first lol
Can you? We encourage it, along with a hi flow air filter...
Didn't you say
Go with that & you should be ok...
Definitely a torque converter, it's an auto trans of sorts, AKA CVT or Constantly Variable Transmission...
Tanner9690
Tempe Az. USA
Thank you guys so much and yea fabroman I forgot I said that lol it's been a long day. I am a fabricator! I build the steel vacuum system for the machines that suck out sewers . So I am not familiar with anything automotive lol and now I was looking at torc converters is there a specific brand. I have read that comic torc converters are good. Which one is rated high enough for an 18 hp engine
You're good to go then :thumbsup:
Warning: The torque converter will set you back around $350 but, it's worth the expense...
What model plan did you get?
Oh, BTW, can you please fill out your profile so we know where you are? It makes suggesting parts sources easier (for one thing)...
Tanner9690
Tempe Az. USA
yea sure I got the Velociraptor plans I am going to put a full suspension on it and make it similar to a Honda FL350 odyssey. but way better ill post some pictures soon
carter
:thumbsup:
Man! that is exactly what I want. That just put the biggest smile on my face! that kart sounded AWESOME!
They can sound even better than that, I've heard some that would give a harley a run for it's money in terms of sound.
Also the engine they showed in the video above is ridiculously powerful, to the extent that when they did a ride video of it they floored it and it chirped the tires and then broke the sprocket hub.
Tanner9690
Tempe Az. USA
Yea I saw the rest of their videos. I was looking around our shop at work today and found a similar motor to that one that I want to put in my kart now. I'm a little more responsible than those guys and my kart and shaft are a little heavier I'm going with a 1 1/4" shaft at a minimum
rushking19
Richmond Virginia
They were pretty irresponsible because most likely the hub wasn't on properly because it's usually the key way that breaks first and plus all the grip from the tires and they would let the cart roll back and while it's still rolling back just go full throttle putting stress on the hub
Tanner9690
Tempe Az. USA
Yea. That's probably what happened. But now I was thinking about it. I think I am going to wait and collect me stuff and do some more research and enter this build in the 2015 build off:auto:
