Clutch Teeth & Sprocket
Zman5555
New York
Was wondering what u all think would be a good combo to get the most acceleration & power on a 1/8 mile dirt oval track . I am currently running a 13t cheetah & a 64t rear sprocket . The acceleration on take off & out of corners is pretty quick but straights i lose on . Any ideas to get this 5.5hp @ 6,000 rpm faster . Thanks !
hmmm
I'm not sure a higher gear ratio will work better than yours.
and here's why.. you run a 5.5 engine, that roughly provides you with 7-8HP;
the max power though is NOT at max rpm, it's roughly at around 5000-5300 rpm
assuming on a dirt track you run like 13" wheels on the back and with you in it the kart weighs not much more than 125kg
your gear ratio should propell the kart to nearly 45mph with an acceleration of ~2.7m/s²
anyways.. that speed is about what you could expect with ~8HP
Okay, I can't say what your engine provides in reality.. how could I;
but 8HP sounds plausible to me for now;
But if you now try to reach more speed with a different ratio, you might end up loosing acceleration WITHOUT adding top speed.
chances are quite the opposite will work (that is if you do not reach max rpm at your top speed)
taking a lower ratio will improve acceleration, and -if dialed in perfectly- provides more torque at top speed, and that allows for more top speed..
Again, without having the exact details it's hard to tell for real;
but at least mathematically you should be aware that a higher ratio might get you nowhere when the engine is not yet powerfull enough.
[strike the following; I misread a number]
now you run a 5.15 : 1 ratio...
stretching it to 4.47:1 (15T clutch) sounds to high for me.
4.79:1 would be the 14T clutch sprocket just so you know ;)
[/strike]
oh :oops: ... I could've sworn I read 67....
must have been hallucinating ;) my fault!
well then... you can still try if you're confident that your engine provides more than the 8HP I assume;
but be warned to reach 50mph you need at least 7.6kW (on your wheels!) for a dirttrack.
that's 10.2HP
Zman5555
New York
Raced yesterday & kart was not handling at all . The kart is limited on adj set up but will try to correct & then work on the gear ratios . Thanks for all the input & would anyone give input on a particular clutch over another ?
zbuck
Ft. Wayne, IN
:wai: Sounds to me you need to balance out that kart. What are your cross weight numbers? Do you have any rear tire stagger?
