cart takes off after engine rebuild
carter
Hey friends, I just finished doing what ended up being a rebuild of my engine, I started it for the first time, and as I let go of the rope and lit up with glee, it proceeded to speed away from me and wedge itself under my deck and bend my nice roll cage.
What could cause an engine to take off after starting? I had the engine completely apart, and put it back together. I couldn't help but notice the governor isn't holding the butterfly open, so I opened it and it rested there, when I got to it stuck under my deck it wasn't that far open. Is something wrong with the governor perhaps? maybe I hook my throttle back up wrong? it bolts to the engine so I wonder if maybe I bolted it too far away from the linkage? Maybe the distance from my 500 series drive to driven is too wrong? I already checked it and there is a fair amount of slack in it but I wonder if that's not enough?
Half-breeder
"Edit" button removed
OK... what kinda motor... Im 'guessing' your using a TC/CVT instead of a CC(pics would be really handy for those that dont know who/what kart/engine you are talking of... this 'is' a new thread...). Did you change ANYTHING bout the TC or was it 'just' a engine rebuild? Are you sure you put all the pieces of the TC in the proper placement? Possible 'maintenance' may be needed for it? Did it run well before the rebuild? Did it take off at an idle rpm or wide open? Do you have return springs inplace?... alil more detail would be quite handy.
The most likely scenario is high RPM, either because the idle is set too high or there's an issue with the governor/throttle setup
carter
Sorry guys, I try to be descriptive and then describe the wrong things. It's a tecumseh HM100. This is everything I did to it.
*decked head, sealed with permatex super 300
*replaced side cover gasket
*replaced compression rings
*replaced exhaust valve seal because I lost it
*lapped valves
*cleaned up some casting marks inside the head
So I looked at it and noticed the little arm that the throttle hooks to wasn't quite sitting on it's bottom rest, I fixed that, then I put it about an inch from a tree and started it and it still pushed itself into the tree, after I yanked the butterfly closed though it started idling right, minus the muffler smoking a bit though I suspect that's due to the fact that I wire wheeled it with a wheel that had some oil on it. I'm gonna take some degreaser to that and check again next time.
Whats strange is the arm the throttle cable hooks to is returning fine, however the arm that the butterfly and governor are on do not. without the engine running I went up and stepped on the gas and the arm the throttle cable is on came back but the one the butterfly and governor are on stayed at WOT. Is that normal?
Half-breeder
return spring return springs return springs.... and if ya didnt catch that... return springs.
carter
Sorry, I fixed it now, I forgot the difference between private and unlisted
Half-breeder
... yea that coil/spring needs to be mounted preloaded... in other words when you place one end in that 'slot'... you are going to have to wind it possibly 1 revolution, as you are inserting the other end in(or visa-versa), it's a kinda trick labor to do. The idea is that the coil will retract the throttle back to idle position, while keeping tension on the governor(but not too much tension that it limits the governor to engage at the appropriate rpm) during acceleration.
carter
Well the torsion spring is what links the throttle arm and the governor/butterfly arm. It actually does not pull the gov/butterfly arm back the other way. What I was wondering though, is if maybe I could just put a return spring on the linkage somewhere or on the governor arm itself?
I tried to explain and show why I couldn't wind the spring another wind in this video and show it.
https://www.youtube.com/watch?v=ds3FEmI5lY8
Sorry If I'm not quite making sense, I'm a bit frustrated because I now have a roll bar to fix.
carter
Hey, sorry for the double post, but should my throttle linkage be able to open my butterfly all the way to the stop when the engine is off??
