MancoGX390
Just tinkering...
With my GX390 i want to get more revs out of it, would bypassing the governor be ok because i don't really want to open up the crank case?
Also this is probably a stupid question, when you re drill the main jet, like I did with my GX390 , I drilled it from 1.00mm to 1.10mm, you know the little but that also falls out when you remove the main jet, does that need to be changes too?
I don't know what it's called the other tube like brass bit that falls out with the main jet, could be the emulsion tube, does that need to be changed?
What does the tube do and what size would I need for a 1.10mm jet?
So if i was to buy another stock honda emoulsion tube as a back up i could take the old one out and add 1 or 2 more holes and see if that fixes my laggy idle...
Sorry to bore you with more questions about the GX390 but i have one thing i really wanna find out. If i buy a billet rod and billet flywheel and pull out the governor, will i get any aditional speed considering the max rpm of the 40 series is 3100rpm?
