Resistor plug and cap.
krn123060
Hi folks. First post. Be gentle. I am somewhat confused regarding the resistor, non-resistor situation. I have a Predator 212 and was curious about which system it ran. I was led to believe that stock ignition was resistor but the stock plug is shown as a non resistor and when I pulled the plug wire apart I saw no resistor. Just curious as to which way it is set up. Does running a resistor plug in a non resistor cap make ant difference. Is this even an issue? Thanks all.
zbuck
Ft. Wayne, IN
:wai:The resistor is in the boot, thats assuming that the boot is made of some kind of plastic composite/bakelite. not in the spark plug wire its self. You Can buy non-resistor boots. As for difference I have no idea.
machinist@large
West Michigan, 49331
The resistor is just to control electronic noise that would potentially affect radio and TV reception, and is internal in the plug wire. The easiest way to find out what type you have is to dial up an AM station on a cheap radio, and have someone listen to it while you run the engine.
Stolen from the NGK website:
Q: When should I use a resistor spark plug?
A: NGK "R" or resistor spark plugs use a 5k ohm ceramic resistor in the spark plug to suppress ignition noise generated during sparking.
NGK strongly recommends using resistor spark plugs in any vehicle that uses on-board computer systems to monitor or control engine performance. This is because resistor spark plugs reduce electromagnetic interference with on-board electronics.
They are also recommended on any vehicle that has other on-board electronic systems such as engine-management computers, two-way radios, GPS systems, depth finders or whenever recommended by the manufacturer.
In fact, using a non-resistor plug in certain applications can actually cause the engine to suffer undesirable side effects such as an erratic idle, high-rpm misfire, engine run-on, power drop off at certain rpm levels and abnormal combustion.
True that this doesn't really apply to go karts and such, but it gives you an idea of the kind of EM distortion they can create.
I've heard it said (I have NO way of accurately measuring it) that you do get a hotter spark without.
