Grey/silvery oil
freakincage
Winnipeg, MB, Canada
When I drained the oil to do the governor removal, the oil was a normal dirty brown. I refilled the crank case with Mobil 1 synthetic SAE 0W-40. After a few hours of running, I checked the oil and it was grey and kind of silvery. I drained the crank case and refilled with the same oil. A couple hours later the oil is the silvery grey color. Am I using the wrong oil?
KartFab
Generally speaking you should be using 10w30 for 'normal' areas, and 5w30 if your going to be in a very cold/freezing area.
Some particular engines require detergent or non-detergent, or just straight cheap 30 weight.
It doesn't sound good. .....I'm not familiar with that oil.....but it could be metal....IDK......
I would just run some straight non-detergent SAE 30w and check the color of it. .....you can save the high dollar stuff...and if the 30 looks Ok....I guess you could use it. .....:surrender:
The oil you're using is too light &, as a result, is not lubricating correctly & the engine is eating itself...
That grey/silvery colour is metal from the engine internals; get the oil out, fill the engine with a heavier oil & pray you haven't done too much damage
freakincage
Drained the oil. Filled with valvoline SAE 30. Oil is same color after only a few minutes. Drained and refilled and ran. The oil is almost normal color now. I guess there is still some residual crud in the crankcase. The motor had a bit of blow by before and it seems to be worse now but the engine still seems to run well enough.
If I decide to change the rings, do I have to hone the cylinder or can I just replace the rings?
I disagree. ...because detergent oil does the same thing as low viscosity oil...clean instead of lubricate....better to err on the other side. ....
Jmho.......
That's very likely...
The simple fact is, damage has occurred, the only variable is the extent of the damage...
A very resounding YES! New rings need a new surface to bed into; replacing the rings & not honing will mean the new rings will bed into the old rings grooves & wear them out a lot quicker... not to mention the lost compression while that happens...
Half-breeder
"Edit" button removed
I have to agree w/ what they are saying... oil is either too thin... or its possible you already have too much cylinder damage. I had a similar issue... this is what I had to get to remedy it...
...hopefully your cylinder dont look like mine did... I had to remove .020 just to get a good seal...
freakincage
Rings are burnt. Still runs good enough and I don't hear a rod knock, at least I don't think I do. Still has ok compression but is burning oil. I didn't realize that there were different grades of 30 or 40 weight oil. I always thought 30w was 30w. Ignorance is bliss I suppose. Idk if I'll rebuild this or run it till it's dead and put on a different motor after.
freakincage
That's the plan, except for the modding. I can get older 5-8hp Briggs around here for $65 all day long. If I do buy a brand new motor, it will be going on a new build. I'm thinking of copying this chassis and doubling the width for a 2 seater. This will be a winter build though.
