1985 Vulcan 700 for a kart?
John42
I am brand new to forum, without much skill as a mechanic.
I have just purchased today, a 1985 Kawasaki Vulcan 700 with the transmission for 100 bucks. It needs some work I am told, and I will take it to a small engine repair shop to get it going.
Now the more important question:
Will this be a viable engine for an adult go kart?
John42
Hmm, ok. I thought I read that these engines could just have a sprocket welded on the shaft, and a sprocket welded on the rear axel - with the engine mounted on its' side.
Are you positive that is not possible?
ML-TOYS
long island, new york
I have a motor from a trike that had driveshaft. I removed the shaft section and have the drive gear visible. Theres a nut that holdsx it on so i am gonna try to figure out how to swap it with a sprocket. On this engine the gears are fabbed with the motor so its all one setup for me. I can snap a pic of what my output looks like if you want a general idea.
I have never heard of a drive shaft engine being converted to chain for a kart. It might pay you to sell the engine for a more suitable one.
You say that you have limited skills. To try and get this engine to work, having limited skills, will be near impossible.
firemanjim
Just kartin' around....
Houston Texas
It's possible, it's been done, I've seen it done, I've done it....... :thumbsup:
When I did it with a Honda 250ex engine, I used the hub that goes onto the splined out put shaft. I machined it so that I could center a 14 tooth sprocket and drilled/tapped 3 holes @3/8x24..... Mounted the engine cradle side ways on the kart, and lined up the sprockets. The hardest part is setting up the shifter.
I agree with landuse. Part out the bike you got until you got enough bread to buy a dirt bike engine. You'll be glad you did.......
John42
Thanks for the advice guys. I'm going to explore a RAGB also. First things first. Going to get the engine running and look at all possible designs. I have help. 2 neighbors have become really interested in this project as well. Money isn't the biggest concern - putting a monster, 1985 - 700 cc engine on a gokart that can hit 150 miles an hour, is the goal.
ML-TOYS
I found a body for your project, and a final trophy :roflol:
