Making a stainless steel rose flower.. (semi embedded pic heavy)
andrewmacc
Canadian Wonderboy
Surrey BC Canada
So I had in my mind for a while to try my hand at making one of those steel flowers. What held me up for a while was that I didn't care much for the natural "patina" they develop from humidity over time, nor did I want to paint it.
Having inevitably just ended my relationship (which is a shame), I scoured the seven seas (unintentionally) and met a nice young lady who tickled my fancy, and I felt like making her something unique.
And thus, after a year of absently thinking about this kind of project, I finally grabbed some stainless steel 20ga sheet and some 1/4" stainless round rod.
There are templates all over the web, because this is not new territory, so I shamelessly printed them out, cut them, and transferred them to some nice stainless sheet with the protective layering.
Excuse the consistent mess in my garage. My garage is as cluttered as my mind.
I roughly cut them on the bandsaw, after a very short stint of trying the jigsaw, which just wasn't happening. Which is fine, the bandsaw was the much better choice.
I picked up some 3/32 309L filler wire, but only because they had no 1/16. That proved to be a small hassle, as the 20ga wanted to burn out before I could wick some filler wire into the pool. I ended up around 56 amps which was just enough to very lightly penetrate the 1/4" rod and lay a small tack.
First tack and bending the middle of the bud straight up.
That's the first layer, after using some needlenose and squarenose pliers. Having laid a tack in made it much more pliable.
Second set of petals
We're almost there.
The last two sets of petals I tried to peel backward a little for that natural droop of the petal, but that ended up working out better on the second rose.
Ta da.
I used a chisel and hammered some little texture lines on the leaf. This project would work faster with about 22ga to 24ga sheet metal, and easier to create texture and bumps. 20ga is the limit IMO until it becomes a pain in the butt.
Not bad for a first try, in my opinion. The second one went about three times faster:
Texture
Anyway, so that's that. Just thought it would be cool to share. :ack2:
B.M.800
TheBeal.
Central PA
We did something similar in weld shop, we used used thin sheet metal. Brazed it together.
Not too pleased with it now after brazing...
Was gona make more, but never got around to it. Maybe Ill make a mess of em sometime...
A fun little project for sure. :thumbsup:
andrewmacc
Canadian Wonderboy
Surrey BC Canada
Thanks Andrew. That is cool!
Thank you! I had a lot of fun making them - I've never made something that had absolutely no purpose other than to look good, so it was an experience..
Wow, those look great.
How did she like them ?
We'll find out soon! :popcorn:
Her and I met on Vancouver Island, but I live on the mainland. Very close but a ferry ride away. She moves here in September for school (like I), but in the meantime, don't they say absence makes the heart grow fonder? :lolgoku:
:funnypost: :kewlsmiley:
Nice!! Roughly how long did the actual fabrication take you?
I'll admit, the first one took like 4+ hours. If you're not a dumb dumb like me, you could pound out a first one quicker than that. But by the second one I knew how I could speed it up, so it took under 2 hours to make the second one.
The time will increase again because I want to try new ways and designs, I didn't think I would enjoy doing this like I do. I made a third because I have enough stainless left over for 4 more roses, but I also did it because I showed a friend and he offered to pay me to make one for his lady.
I was worried that making more would cheapen the sentiment of having made her the rose first, but in my eyes, the motivation I got through wanting to do that for someone opened up a world of weld/fab that I've never ventured into, and I think that's equally as awesome.
That's great. Now you can give her a rose that will never wilt!
My thought process as well! I thought, well, I don't like buying flowers, because they die. I happen to be reasonably good with metal. Hm. Metal. Flower. But steel flowers can rust, and I don't want to paint it. And I've never worked with stainless steel before, so this was perfect.
Thinner sheet would be better, but 20ga was the thinnest they had at my local metal place down the road. I could have scoured for thinner, but I knew I could at least make it work with 20ga.
Never brazed before! Not a drop. How'd the brazing part go?
I like the leaves on the stem. I thought about them, but I really liked the elegant simplicity of the stainless stem with just two small natural looking bends in them.
Here's the one I whipped up for my friend:
B.M.800
TheBeal.
Central PA
I cheated in that picture, I used glue to hold it together for the moment.
I would have preferred something a bit thicker, if you arnt careful youd burn through what we had to use. The material we used came from paint thinner gallon cans. I have about 4 stashed away for when I decide to make some more...
