FWIW- I drill my own jets, frequently.
In order to do this, you need a wee little precision hand drill properly called a "pin vise or jeweller's drill" and a set of numbered bits (typically in the #61-80 range) I will tack on a picture of the right equipment. What you need can be had for under $20.
Assuming you're running lean:
Begin by shutting off the fuel, draining the carb, removing the bowl, and pulling the jet out. Use the smooth, shank end of your bits to determine what size your jet orifice currently is. Then select the next size up, and chuck it into the pin vise. Drill the jet to that size, and be careful to blow out any remaining chips. If you choose to use compresed air for this, take my advice: hang onto that dang jet! I'm still missing one...
The brass drills easily by hand and won't take but a minute.
Reinstall jet, and reassemble carb. Start engine, warm to op temp, and do a full-throttle, full load pass. In other words, step on it hard and keep your foot down for a minute. Kill engine while at wide-open throttle, and allow engine to cool.
Remove spark plug, and repeat process as necessary.
Avoid the temptation to skip up a size or two. One size at a time. It's easy to overdo it.
IF you overdo it and end up running rich (been there, done that) use a plumber's torch, flux, and solder to close the hole. Redrill to last known lean size, and continue process.
As stated, you've got it right when plug comes out tan to chocolate brown.
This sounds tedious, it's really not that bad once you've done it once or twice.
