Engine doesn't move the kart.:(
Angel
Ploiesti, Romania
Hey guys, 2 days ago i finished building my go kart but now i'm kinda upset. When i pull the throttle the engine's axle is rotating faster but it doesn't move the whole assembly and the clutch smells burnt. That's a pic of my transmission :
Any advice?
I'm going to guess, you are going to need a bigger axle pulley, I'm going to assume the 6:1 ratio still aplies to pulley.
so i should use a six times bigger axle pulley than the engine' as mckutzy said?
Maybe, but that size might be larger than your back tires...
We could give you better advice If you measure and post, what size your engine (clutch) pulley is, and also tell us how tall your back tires are?
Angel
Ploiesti, Romania
clutch pulley has a diameter of 7cm, axle pulley has 11 cm and back tires have a diameter of 25cm. But would a variator help?
Wow, Your 7cm clutch pulley is 2-3/4" diameter, that's equivalent to using a 21 tooth (#35 pitch) clutch sprocket...
Your 11cm axle pulley is 4-21/64" That's the equivalent of a 34-tooth axle sprocket, and that calculates out to your current gear ratio being a 1.6:1.
Your 25cm rear tires = around 10".
_________________
You'll need to install a jackshaft (like the 4 pulleys in this picture) if you want to use your belt clutch.
Is that what you call a Variator?
If you install a jackshaft on your kart:
You could use your 7cm pulley clutch, with its belt running to a 22cm (9") jackshaft input-pulley.
And then you could install a 6cm (2-1/2") jackshaft output-pulley, with the second belt running to the 11cm axle pulley you already have on your kart now. That would give you around a 6:1 ratio that should work good on your kart :thumbsup:
