stlcards1
The motor is out on this yerf dog and I was wondering if the motor from harbor freight will work but im not sure of the model # any help would be great and thanks for all that give answers.
So the engine cranks and runs?
The yerfdog looks like early 90s but I'm a beginner. I've got a 2006-2008 (not 100% sure which) and there are several differences between mine and yours. I just put the 6.5hp predator on mine and there is quite a bit of work involved, but if you're handy or willing to learn, it isn't that bad. The shaft on the predator was shorter than on the tecumseh that was original to mine but the comet 30 still worked, I just had to get a longer bolt for the driver. The positioning was also a little different so I had to go up a size in belts. You may be able to move your engine around a little to alleviate that but it could affect your chain drive.
That engine you have on there is possibly not the original. Yerfs seem to be fairly consumer friendly which basically boils down to more housings for everything and yours doesn't seem to have any, but again these are just my observations from researching mine. I like your front steering setup better than mine. I have virtually no clearance when turning. I have the turning radius of a 1942 Ford tractor.
Boy they run good when you get them going though. That 6.5hp predator is quite a powerful little engine with that sprocket setup. Have fun!
Make sure you loosen the 10mm nut on top of the linkage.
