extreme gear ratio
TheNewCarter
Thy Art is Murder
Woodland Hills, California
It's a bit of a read.
Well guys, my current gearing is a 10 tooth clutch with a 54 tooth sprocket. My engine set up is a 212cc predator; intake,straight pipe, #37 jet, bigger emulsion tube, and that's about it. My cart in total weights about 225 pounds with me in it. 15x6 inch tires in the back and 13x6 in the front. I'll post an older video I have of it. But anyway my current ratio would be 5.4:1 and so far after about a years abuse it still hasn't given out. I go up huge hills and all. I use a #40 chain. Now I want to gear down even further... Why? Well because my go kart constantly burns out and the price of tires is getting to me... So when that 48 tooth sprocket(yes i ordered it already) comes in I will be running a 4.8:1 ratio... How long do you think the clutch would last if you had to guessitmate it. I am honestly surprised the clutch has lasted this long so far... But hey I am not complaining.
https://www.youtube.com/watch?v=uZXiZsec9cM
Half-breeder
"Edit" button removed
Well... I personally dont know what it 'feels'/acts like to have a ratio like that. I do know that everytime a cent clutch is engaged and a drag on it... it tends to heatup the outer hub to an UNBEARABLE temperature and will continue to do so until a 'nominal' amount of drag is relieved from it. The heat is being produced from the clutch not 'grabbing' the drum firmly, and slides... which in turn causes friction/wear. By doing this enough times... eventually either the material wears away to where theres nothing to grab... or itll 'possibly' glaze the innerds to where nothing moves... just slippage.
...and the reason your burning tires is your foot is pushing that pedal down too rapidly. If a slower/more 'gradual' movement of your foot, forwards, is applied... vwalla... amazingly enough the tire will be less likely to 'break-loose'... but that in turn will cause a 'drag' on the clutch... so lesser of 2 evils I guess is your choice.
Not sure your ratio equations, but here are the ones I do know. They are 'close' to yours, but Ive never run a 15" wheel...
5:1 on 10"=7.5:1 on 16"
5:1 on 16"= a new cent clutch every 2-4 hrs depending the rider weight(did this 3 times...then got a TC...)
... just my .02yen
TheNewCarter
Thy Art is Murder
Because what you gain in top speed, you lose in acceleration BUT, as it reads, your acceleration is rather poor ATM anyway because you can't gain traction on take-off (am I correct so far?)
As for
How long is a piece of string?
My acceleration is fine if I feather the throttle. I don't need it to wind up so fast anyway hence why I am gearing down. I AM looking for top end. Not bottom end. Also for your string statement, if you are going to quote me, quote the whole thing, hence why I typed "guesstimate." I know no one can come up with an obvious answer, I was just fishing for those with similar set-ups.
Don't forget that you do not only need torque for take off;
you need it all the way up.. and at some point
it'll be hard for the torque you provide to the rear wheels to counteract the force the road, the air and nature in general is applying to your kart in the opposite direction.
So even a bulletproof clutch (and yours isn't) would not get you a higher top speed.
Allow me to explain that more visually:
what you see here is a graphical representation of the power you need for speed (ha ... need for speed... :D)
it's calculated for a 125kg kart (275 lbs) but smaller wheels...so I think close enough
to be relevant.
the x-axis is speed in m/s where as the y-axis is power in Watt.
starting from the bottom up,
the yellow line represents the power that only the tyres consume by friction
the green line represents the power consumed by a road inclination of 5%
the blue line is a simplified acceleration curve.
starting with 4m/s² dropping down gradually to 0m/s²
the red line is drag (air resistance)
Now the important part: the two violet lines are BOTH a combination of the previous,
the lower one for a perfectly levelled road;
the upper one for a road with 5% inclination.
10m/s are ~22.37 mph btw.
let's just say with a very mild modification of your predator you ended up with 7.5HP instead of 6.5...
that's roughly 5500 Watts
as you can see from the graph it's impossible
to reach a top speed above ~18m/s (40mph)
and that's for a perfectly levelled road.
I don't know what final HP you now have; so I cannot tell you how fast you can go;
But I assume you're in the 45 mph region ATM (~8HP)
And that's basically already how fast you can go without further modification of your engine.
If you do not come close to that speed, you lost too much torque already, and you can go faster by gearing lower.
if you insist on gearing higher, be aware that you might even loose top speed.
and not because the clutch will fail, but because of physics ;)
I said you would be dissapointed because with a 4.8:1 ratio you might not even get your kart moving from a standstill. This would be because of clutch slip and the loss of torque (including all the factors Sid listed). I am not trying to be a killjoy, just being realistic. A 4.8:1 ratio on 15" tyres is NEVER good, especially with just a Predator 212 engine. If you had a 11HP engine I might believe it could happen
TheNewCarter
Thy Art is Murder
Well to solve my issue, I will GPS my speeds, ill check tire pressure all around, and repeat when the new sprocket comes in and see what happens. Like I said, I am not looking for performance gains, just to lose some torque in the low range so I stop going through tires. It also doesn't help this kart isn't live axle like my one that got stolen. So all the power goes to 1 wheel.
Hambone
Boaz, AL
I would think that a torque converter would handle the higher ratio better.
I run 5:1 ratio with 18" tires and a torque converter, it can still sling gravel in the driveway.
Mines a live axle though.
A torque converter will handle a higher gear ratio
yes.. at the costs of a new belt every now and then ;)
While a torque converter itself reduces your gear ratio
for a good take off and thus makes your kart move on ratios your clutch cannot handle anymore,
it's weakest spot (the belt) will suffer from a bad ratio as much as a clutch would.
TheNewCarter
Thy Art is Murder
I rather stick to buying clutches, then belts, so far with my 5.4:1 ratio the clutch has been going over a year strong. So no complaints from me. Still waiting on the sprocket... Ebay seller is soooo slow.
