help tearing down?
carter
This might seem really stupid and I'm sorry if I missed a sticky or something, but I have my engine torn down so the only parts left are the crank, rod, piston, valves, and cam. From here I really don't know what to do. Everything is put in in a way where it seems like it's holding everything else together.
I want to get it completely torn down so I can do the head gasket removal/compression bump shown in the stickies.
carter
I don't know how I didn't notice this, but the crank bearing is holding the cam in. Is there any way to remove that without damaging it?
carter
I have a couple pictures, it's on a Tecumseh HM100.
carter
I needed to replace the crankcase seals anyway, so I figured while I was at it I'll lap the head and block as in your sticky. I'm also considering polishing the surface on the underside of the head where the valves go, there's alot of ugly casting in there that could be made better.
How does one remove this bearing? or does it not come off the crank?
carter
terribly. How can i remove the cam and the crank at the same time? the piston and con rod prevent that.
carter
I'm not sure why that didn't click in my head, I started early this morning and was just dumbfounded by the thought of how to get that thing off, I had a flexable extension and everything, I was thinking more clearly a bit ago and went and got my deepwell 3/8 and the only trouble I had was breaking the bolts loose.
Last question, the valves. Do the keepers/retainers work in the same way they do in a large engine where you push the retainer down and then the little keepers slide out or no?
carter
Actually I'd forgotten to remove the flywheel until I already had the side case off. what I did is I took some fuel line and some vice grips and got the line real tight on the cup for the recoil starter, then I just used that as a handle while I loosened the nut.
It was sorta like an oil filter wrench.
I'll have this thing down to bare block within the hour now.
Russ2251
AZUSA:Powered by LAWN-BOY
Keep in mind that when removing flywheel, side cover should be in place for support.
If this procedure is not followed, there is a good chance that case could become distorted or worse.
Russ2251
Oh No!!! I mixed mine on disassembly . I have a Briggs flat head 5hp
How can I tell the difference?
The reason for not mixing the tappets (lifters) is that there is a spec for valve lash (gap). This lash is adjusted by grinding the valve stems until spec is met. If tappets are switched, this could (possibly) give you incorrect lash on both valves.
