GX160 vs B&S 900 series
ginoz28
central TEXAS
I want to make myself a small frame yard kart. I'm still looking for a frame, been looking for a american express type frame ever since I seen fabroman's build.
I have a Honda gx160 from a compressor and a b&s 900 that I still have on a generator. I wanted to see what was a good engine to find hopup parts with good power.
Sent from my HTCONE using Tapatalk
rmm727
Brookville, PA
The generator engine might not have a straight shaft you need for a clutch. The compressor engine probable does. I'd buy the compressor throttle control parts off you if you would use that engine and want to sell.
ginoz28
central TEXAS
The gx160 has a straight shaft , I need to put the engine out of the generator to see the shaft.
Rem727 what throttle control s are you talking about. The cable off of the compressor or the linkage on the motor?
r97
Measure twice cut once
Massachusetts, USA
The Briggs is a good engine that will have more power to start with, but I don't know what's available for performance parts for them. I bet there's some decent stuff available. The honda on the other hand has tons of performance parts available, not to mention being a great engine to start with.
But as already mention the most important concise ration is the PTO shaft. Using an engine with anything besides a straight 3/4-1" OD 2-3" long keyed shaft makes fitting a clutch significantly more difficult. Drilled and tapped end if you want a CVT. Therefore I'd choose whichever engine has a useable PTO, even if that means sourcing a completely different engine.
ginoz28
central TEXAS
I'm going to to some research on the b&s about the shaft. The generator still works and I don't want to pull it apart yet. Here a pic of each engine.
ginoz28
central TEXAS
If there are different types of 900 series I don't know but this has the right shaft.
ginoz28
central TEXAS
Every different 900series I look at has the same shaft. The only thing different on one of them was the 6:1 gear ratio.
Russ2251
AZUSA:Powered by LAWN-BOY
The complete number off the Briggs engine will tell you if it's a tapered shaft or not...if you know how to interpret it.
I have never seen (in decades) a gen-set engine that did not have a tapered PTO.
This isn't to say that they do not exist...I've just never seen one.
The reason for the taper is to aid in "locking on" of the rotor. Analogous to placing 2 similar size drinking glasses inside each other. Very difficult to get apart.
To remove an engine from an operating generator for gokart use makes no sense...given the expense of a gen-set and the amount of otherwise usable engines out there.
ginoz28
central TEXAS
I don't see any numbers on it. I want to see if it was common for people to build these engines. I have been searching the gx 160 and there are plenty of aftermarket parts for clones also, so I guess I'm going team Honda even though I was hoping for tha American brand.😢
ginoz28
central TEXAS
Your right, I was googling and its only trying to sell to you with no specs on the crank.
rmm727
Brookville, PA
Looks like your already missing the throttle control parts from the air compressor. The items I'm looking for idle the engine when the tank is full and throttle it up when its not.
ginoz28
central TEXAS
All the parts are there but I'm going to use them. The only thing that's off is the cable from the tank to the linkage that's still there.
Hang on, If your inspiration was my kart, why are you considering anything but the Honda? Performance parts are more readily available than B&S preformance parts & you should be able to gain a signicant amount of hp with a few simple mods...
ginoz28
central TEXAS
Calm down I'm going with the Honda.
I guess the far east wins this time. I like to stick with American brands.
