Quick advice on Briggs Motor
2SlickNick
American Minibikes @ FB
Mesa, AZ.
I am going to leave tonight to pick up a 5hp Briggs for $40
The guy states it runs, has a spare carb and tank. Looks as if it attached. The tank and carb mount on the side.
No airfilter but states it was not run without it. Just to start it..... Says it was left on an old yard machine wood chipper. I guess it is what you all refer to as a flat head....?....
Anything I should be aware off?
Look for?
I assume parts are easy to get....
Looking for your opinions before I leave to get it?
It sound like a decent deal....
Thanks in advance.
KartFab
Compression test, if bad compression don't buy., but for $40 it's a really good deal if you don't mind parting it out. They sell plastic aftermarket air filter housings for them (if it's missing one?)
Tanks go for $$30, recoil/shroud $20, coil $10, crank cover $30, crankshaft $15
(That's if u part it out how much u can sell parts for on ebay)
Check the oil, if it's black with grey particles in it it could also mean bad news.
If you don't have a compression tester, pull on the cord slowly, you should feel it catch every time the crank turns a little bit. If you pull on it slowly and it doesn't 'catch', it could have bad compression.
2SlickNick
Mesa, AZ.
Okay, Thanks...
So worse case scenario ( I could recoup any losses over time ).
I am trying to borrow a compression tester I lent mine out 5 years ago and never got a new one:feedtroll: )
I will check oil and do cord test though....
Will practice on my other briggs 6hp now....
Great advice,thank you, but .....:useless:
will upload the pics he sent me in a minute.
I would jump all over it. ....I wouldn't even worry about compression. ..if it runs ....it would work for me..
Of course. ....I would just rebuild It as a matter of course. .that's just me. ..cheap and easy to do and worth the money just for the experience. ..
A few things. ....the extra carb and tank are likely the originals. ...chipper shredders have a rough life....they often spend their lives outside without protection. ....it's rare that an engine outlives the chipper....unless something happened. ...or it was really neglected ... (outside) and the flails or something rusted up......
Another thing is that they suffer even more from neglect in maintenance than lawnmowers do..... (never get an oil change. ....)
Finally. ....if the PO ever shredded dry materials. ... (which I often do)....then it was operating in extremely dusty conditions and usually those machines rarely see anything less than full throttle. ....
These are generalities. ...The condition of the paint is a good indication of how much time it spent outside. ......
2SlickNick
Mesa, AZ.
Just picked it up. It starts and has a tapered shaft but keyed.
Still okay right ....?
Will report more when I get home.
2SlickNick
Mesa, AZ.
Okay, I am home and tired,,,,,,,, but I did look at a few things. He said it tipped over in the back of his truck on the way there. It did fire up. The spark plug is wet but I assume that is because it was tipped. No biggie.....
On to the shaft...
It appeared to measure 7/8" on the keyed end.
And appeared to measure 1" at the base.
So big questions are pertaining to shaft.
Do I :
A- machine it down? and how? I am not a machinist nor know any.
B- Remove the shaft and replace it with a 3/4" shaft?
C- other suggestions
Also that carb and linkage system looks intimidating...
2SlickNick
Mesa, AZ.
Not opening a new thread...
Rather than opening a new thread.......
What do you guys think???
I did find a shop that would mill it... maybe $100 ballpark phone quote.
If I purchase one like above link. Is the oil seal part of the crankshaft going to fit?? OR do I have to get a stepped crankshaft? Or are they all 1" at the oil seal part?
