TAV backplate
2SlickNick
American Minibikes @ FB
Mesa, AZ.
Now that's great :D
All you need now is a belt for a 8.25" center distance and a 7" driven...
and the backplate would work.
(well if I measured correctly...)
maybe 203583A will do *shrugs*
which backplate do you have?
mine is cast..
(got myself a complete TAV2 clone)
The sheet metal one... well there's a reason it's cheaper ;)
GTC calls the cast backplate for up to 13hp and the sheet metal one for only 8HP
(same TC just the backplate is different)
that'd make me worry to be honest.
It makes sense on minibikes since it takes up less room...
on a kart I wouldn't even bother ;)
BUT.. more important.. I messed the distance up somehow
don't ask, I have no idea..
but fact is I have a 203589A belt.
that means the center distance must be between 6 10/16 and 6 11/16;
and measuring it.. it's roughly 6.5 so yeah...
*shrugs* I have no idea where the 8.25 came from [most likely a typo converting cm to inches]
So, a belt for 6.625" center distance
that's tight for a 7" driven, but I think it should still fit.
closest belt (symmetric) would be for a 6 13/16 to 6 14/16 center distance (203580A)
I don't know if it'll do it's work but It might be worth a try.
2SlickNick
Mesa, AZ.
mine is cast..
Hey thanks !!! I really appreciate the extr help. My only concern now is if i order the same back plate like you have could I pop out the 5/8 bearings and out in 3/4?
That is why I considered the other one.
I'll measure the outside diameter of the bearings later today and see how big they are.
My best bet for now: no you can not.
But we'll see how big they are and if there are bearings that allow a 3/4" with the same OD.
What you could do however is: get a shaft sleeve to reduce the 3/4" bore for a 5/8" shaft.
[EDIT]
1 3/8" OD..
the Acor BB-9903 bearing is also 1 3/8" OD but with 3/4" ID so size-wise it'll fit.
If it's up for the task, I don't know.
http://www.amazon.com/Precision-Sealed-Bearing-Thick-Rubber/dp/B00I2ZQKM2
2SlickNick
Mesa, AZ.
Look what I found.. I think this might work... The 5/8" end in the TAV back plate with 3/4" threaded on my 3/4" driven.
2SlickNick
Mesa, AZ.
Just thinking about ordering this....http://www.bmikarts.com/Jackshaft-Ki...rt_p_1048.html
because if you look at the above pics; the rear 3/4 square tube would interfere with my driven and a TAV back plate would not accept a 3/4" bore, 7 inch driven
so I am thinking about coming up with this.....
See below pic
What do you guys think?
I would rather do back plate but I need 5/8; 6 inch driven.
So this might be cheaper but more head ache
2SlickNick
Mesa, AZ.
Now that's great :D
So I have measured my distance and I am at 8.5" It looks like the only belt that will be available is the 203583A with distances of 8-5/16 -- 8-3/8
Little tight but if I go to 203584A looks like a little too loose
What do you think??
Well if you make the Jackshaft mount you should make it adjustable (by at least 0.5")
that way you can always set it up to the perfect distance for your belt.
a tight belt will wear pretty soon, so it's going to be expensive in the end.
2SlickNick
Mesa, AZ.
I thought if getting that unit but wasn't sure on the height. I had to make a custom jackshaft that allowed clearance of the driven unit from a brace.
2SlickNick
Mesa, AZ.
I was informed also I can shim the motor.
It i can just enlarge my drill holes in jackshaft plate and slide it back a little.
Post 30 and 31 you can see how I made it. http://www.diygokarts.com/vb/showthread.php?t=25416&page=2
since it sits on a plate that is fixed with the engine that would work with round holes..
since the distance between the PTO and the JS would still be fixed (all you alter is sprocket distance)
So both need to be adjustable..
engine and jackshaft mount, to adjust chain and belt.
