a few engine questions engine questions
davidbooth1991
Nottingham UK
Hi all,
Sorry about the heading I didn't notice.... :s
I am the very proud owner of a dealim roadwin 125 engine, And I plan to use it my buggy. I was wondering If there is a way of installing a different starting method other than electric motor. It does state on the net ( and obviously on the engine ) that the soul starting method is with a starting motor. The one for my engine is 75.00 and then I'll need a battery. I have read on the net about making a special mount for a kickstart on the engine and thenn welding the reduction (starter) gear to said kicker. The mounting plate is obviously to stop the oil spilling from the top of the gearbox. Is this possible or is someone pulling my leg lmao.
Cheers all,
Dave.
davidbooth1991
Nottingham UK
No I'm afraid not it didn't come with one. I got it for free in addition to a swap and he said it runs it needs a cdi, coil, plug and starter asweel as the obvious battery. Thanks for replying
davidbooth1991
Nottingham UK
Also I don't know whether I can get a different engines ignition system to suit mine I have wires that are all cut down but I can get around that. I know that Cdi unit is 8 pin and runs on DC.
It's more likely you've had no response because we're unfamiliar with the particular engine... & we're a lazy bunch*; If you can provide a link to the engine, you may get more attention...
The rule of thumb is "if you can source the OEM parts, use them"...
*Not really but, our motto is "help us help you"; if you make the effort to provide as much info as possible so we don't have to go looking for it, it shows that you're making the effort to find answers as opposed to just sitting back & expecting us to do the work...
Nothing personal, I'm not saying that's what you're doing but, there have been many times when some members expected that...
I have to agree with Tony.....except for the part about expecting us to do the work. ......that doesn't bother me. .....for a regular member.
davidbooth1991
Nottingham UK
Okay guys more than fair. I didn't expect anyone to do the running and you guys have been more than helpful. I didn't go into depth with engine spec because I didn't think it relevant with my problem being a mechanical start issue. But I'll be the first to say you guys k ow better than me so I'll do some leg work and get back to you. Thanks again guys
davidbooth1991
Nottingham UK
Okay guys this is as Much as I know.
The engine is a bike engine and came from a Korean bike and is a daelim roadwin 125 2006. The engine number has been removed but there's an alphanumeric code in a grid I have no idea what it is though.
Its 15 horse power, Single cylinder, Displacement is 124cc. It drives a 5 speed gear box and obvioulsy 1 down 4 up. The engines exterior is a bit seasoned lol but the head, valves and gearbox is surprisingly clean.
I swapped a lawnmower that I saved for some wheels, and a brake system and he said I can take the engine, that it runs it just needs ignition ( cdi, coil, and plug ).
I have downloaded wiring diagrams to try to figure put which ones go where but this isn't my strong point on afraid. I now know that the green and red striped wire that leads under the drive gear is a neutral sensor so now I'm just stuck with three yellow wires and a red wire and a blue wire.
The problem I have is a don't want to spend 100+ on starter and battery if I can fit a Kick start on the reduction gear. I'll take a photo with the cases off on Tuesday so u guys can have a better idea.
As I said above 90 percent of people on this forum know more about engines than I do bit you have to start from the bottom lol. Thanks again guys
davidbooth1991
Nottingham UK
general Specifications.
Engine
Engine type: 4-stroke, 4-valves, single cylinder, chain driven single OHC,
Displacement: 124.1 cc, air cooled with an oil cooler (see pic below)
Bore x stroke: 56.5 mm x 49.5 mm
Starting system: Electric start
Transmission: 5 step return, sequential gear box
Ignition system: C.D.I
davidbooth1991
Nottingham UK
Here are some I already had I will take more on Tuesday and I really hope this has helped abit now you guys are as up to speed as I am. Thanks agian
davidbooth1991
Nottingham UK
Hi all, sorry for all the questions but im finding very little help on the net. The cdi unit I need for my engine is a DC eight pin. I'm not going to use all eight pins as I'm not having lights and rectifiers I'm just wiring a cdi and coil strate from the engine...........so do I still need a eight pin cdi ?????. Any help is appretiated as always guys.
Someone will help you out soon. Hang in there
davidbooth1991
Nottingham UK
questions on cvt transmissions.
Hi all,
I've been researching and watching a lot of videos regarding clutch and variator drive systems and wondered if anyone has worked with these on a kart?? I've never worked with a torque convertor and was wondering how similar they are??? I know the variators come in a 19.5mm bore and keyway then drive belt to a centrifugal clutch. I was wondering how someone would transfer that through the belt and clutch and onto a chain and axle. (All the clutches that I've seen and belong to this system don't have sprockets just a pair of tension plates on the back). This system is used a lot on auto scooters and bikes and I thought it may make hill climbs abit less strainuous on the clutch. Many thanks in advance guys. Dave.
