Which Clutch for Predator (212)
MikeWidd
Southeastern Pa.
I'm going to get my son a new motor (Predator 212). He's 8 and he hasnt completely mastered the Kart yet. So I might as well get hit a new centrifigal clutch as well.
Which clutch would you recommend for an 8 year old. I'm thinking a heavy duty clutch that can be abused a bit, I'm not exactly sure.
Any and all help is appreciated.
MikeWidd
Southeastern Pa.
I have a 3.5 Briggs right now. It's a Hillard not sure model. But there seems to be a sleeve missing on it. when it's running it wobbles and sounds like a train bell.
That's why I figured I would just get a new one as well.
Do you know the size of the top of your head...5/8 3/4 etc.
I havent measured it and I'm at work right now.
Sorry The Kart is a Manco Quicksilver with 5 inch slicks.
Kelly Wood
The Mad Kartist
Salt Lake City Utard
The 3.5 briggs could have a 5/8 shaft. I don't really remember. Predators are 3/4 in shaft. The "dinging" sound is made by some clutches as it partially engages. (e.g. IDLE too high, etc.) If the thing wobbles on the shaft greatly, it's time for a new one. It'll start wearing sideways and throw off everything.
I personally like the noram clutch because it has a ring/needle bearing on the shaft. The others might but for your purposes, just a basic comet type of clutch will work.
PorkChopExpress
illinois
:iagree: I put a max torque centrifugal clutch on my predator 212cc worked well until I broke it due to improper install on my part.:oops:
qtband
St. Louis, MO
Hilliard is a fine clutch. You may be able to replace the bushing in the clutch and it'll be good as new. Take it off and measure the engine shaft. Then post a picture on here of your clutch. Then we'll go from there.
PorkChopExpress
illinois
I had it installed w/o the keyway in place so as I was firing it up on bench to see if it worked and revving it up didn't realize I was grinding it down as I went to test run it for the first time the clutch wasnt even moving the kart under its own weight installed keyway and it ran great but now it's not disengaging to idle.
