Carburetor issue?
Mrenglish90
Ocala fl
Got a go kart that didn't run ( Carter brothers xtv 2150 )
I had to mess with it for a while to figure out the issue. Turned out that the piston got smashed up in the cylinder / engine and they didn't want to tear into it. I broke the whole thing down, replaced the piston new gaskets and all that fun stuff. Put it back together but still won't start. I'm getting spark, and what i believe is compression from the engine. I think the culprit is my carb because it doesn't seem as if my plug is getting wet. At first gas was pouring out because the float was stuck. Cleaned it up but now, small droplets of gas seem to be shooting into the air filter from the Ports under where you attach the filter to the carb. what's going on, and how do i get this thing to run?
Mrenglish90
Ocala fl
There's a screw hole on the left side behind where the fuel valve is, but no screw. Would that make it not want to start?
