When to replace a worn belt and clutch maintenance
gshaffer.usu
Utah
I looked for threads and pictures on this topic, but couldn't find one. If a thread thoroughly discusses this, please let me know... Thanks. If not, here goes:
I am new at this, and don't have too many neighbors or groups of kids to help me know when to replace a belt.
We just got a Yerf-dog, and it "lurches" when first starting to accelerate. From videos I have seen on the Internet, other gokarts don't lurch, etc.
I am thinking I have a worn belt that has a hard/difficult time in the clutch, but I don't know for sure. It is likely the original belt... I have the part number for a new belt (as someone here posted that already), but I would like to make sure that I need one before I get it, etc.
How do you tell when the belt is too worn? Mine is hard, with dents/pocks, and I think it is slipping until the centrifugal clutch has no choice but to "grab it".
Also, I took the clutch off this morning. I figure it needs some maintenance of sorts, lubrication, etc.
So, if anyone can share with me some advice, I would greatly appreciate it. Here is an uploaded video to YouTube to show what I am talking about. http://youtu.be/d9ZVqJYSCH8
Gregory
Felineman
Death by misfortune
Muskoka Lakes,Ont
Spray the inside of the clutch with brake cleaner and replace the spring replace belt and if that should solve the issue. Maintenance is always a good thing. Please fill out your profile so we know where you reside.
Wow, it looks like you need new weights sooner or later as well.
Anyways, give the inside a good clean and DRY lube the contact surfaces (weights, bell contact)
it wouldn't harm to at least check the springs, just untie them and if they snap to a straight spring, they're good;
if they stay bend, you should replace them.
(if you replace the springs or intent to.. get new weights as well... not a big difference anymore ;))
KartFab
Try not to get it on the spring(s) or the paint could come off.
Dry graphite, or dry molybdenum spray (dry moly is best). You can get it at grainger or order online (i think).
Also just my 2 cents. If the weights (looking at the pins that the weights slide in and out of) have excessive wear in the holes, (e.g. look like they are wallowed out) this can cause it to suddenly engage. Chances are you just need to brush out the hub/spline contact surfaces with a wire brush, lube, and it will work.... BUT if it has wallowed out in the weight pin holes (not sure what they are called) it will have issues again. So my entire point is this. weights/springs etc cost like $30. A BRAND NEW drive unit costs $50, so if you have to buy new weights, just pony up and get a new drive unit.
