Hey guys, so I've got a rolling go kart frame with the side mount motor, the racing style frame. It has regular racing slicks (I think 5" wheels?) Anyway, i also have an 8HP Tecumseh snowblower motor. So I did a bit of reading on gear ratios and TC vs Clutch but it all seems to be very specific. So what I want is a kart that I can drive around the yard occasionally but its main use would be road trips kinda. Probably a couple hours at a time usually. I have a Suzuki 125cc 4 stroke dirt bike that my brother rides and for these road trips (usually gravel) I wanna be able to keep up as best as possible. So Id like something with good top end, but also I don't wanna burn through parts if I just wanna rip around the yard a bit (about an acre). Also, I will probably end up going to a larger diameter wheel/tire to get more ground clearance so lets keep that in mind. Id like to gain maybe an inch or 2 of clearance. So I need to know, clutch or TC? And what gear ratios. Money is getting low at this point so Id also like to keep that in mind.
Also, the snowblower has different gears and I think reverse. Would it be possible to use those gears or at least reverse on the kart?
