TAV backplate
2SlickNick
American Minibikes @ FB
Mesa, AZ.
I bought a 3/4" driver and a 7"inch 3/4" driven.
Is there a backplate that will fit a 7" driven???
This will be on a Briggs 6hp intrek.
2SlickNick
Mesa, AZ.
If anyone has a back plate for their Tav unit could you do me a huge favor and measure center bolt to center bolt for me please.
I have a 7" driven and want to order back plate and correct belt ( with appropriate length )at the same time.
the 7" driven doesn't fit on the TAV backplate!
Also your driven doesn't look like a series 30 driven to me.. (I know it's the back.. so how about a picture of the front (driver and driven please)
2SlickNick
Mesa, AZ.
it's most likely not ;)
the driver at least seems to be a series 30 fixed sheave.
yes they ALL have a 20 stamped on it.. nevermind that!
take a photo and we can tell ;)
I don't think so.. no.
2SlickNick
Mesa, AZ.
Here are some pics of the symmetrical angles.
Half-breeder
"Edit" button removed
I run a TAV2... I also "own" a 7" driven... Ill chech tommorrow if theyll work together. You may have an issue w/ the JS diameter(5/8")...
Ah thanks.. wouldn't have thought so.. but it's indeed symmetrical...
must have been the picture ;)
that fixed sheave looks flat to me on the earlier picture...
ANYWAYS
The bad news is: you will need to get a reverse wound driven unit spring to mount the driven the way you hold it in the picture (or to mount it on a backplate)
symmetrical TCs have the cam of the driven inboard.
(the series 20 as well as the series 40)
2SlickNick
Mesa, AZ.
ANYWAYS
Say what?? so the driven needs to be on the left of driver??? if it is symmetrical? What if I turn the driven around?
uhm NO
the driven needs to be flipped!
the cam needs to face the engine, not the wheel.
Nooo.. listen closely!
"the blue spring says it's running inboard"
because it's WOUND (and preloaded) that way.
you can not just preload that spring the other way, it wont work neither well nor long.
you must swap the spring against one that's wound the opposite way (and preload accordingly)
I think (I don't know for sure) the green spring for a series 30 fits in a series 20 driven unit and it's indeed wound in the other direction so it would work (if it fits)
2SlickNick
Mesa, AZ.
It is an outboard driven unit... So no flipping it weird
Now that's great :D
All you need now is a belt for a 8.25" center distance and a 7" driven...
and the backplate would work.
(well if I measured correctly...)
maybe 203583A will do *shrugs*
