8HP Flathead Mild Build Help
solomon
ca
Building a mild 8hp briggs flathead for a mini bike. Just doing a custom intake and exhaust, freshening block. Pulling the gov and drilling some oiling holes. Question is, what rpm will the springs float at on an 8HP?
88nightrider
Norway, Sandnessjoen
I have been searching around a bit on you question.
Can't say how reliable this info is :huh:
that engines heavy and good for a bigger cart but a little much for a very small one. they can run about 4000 rpm or so before the valves hold them back as i remember
Source
I seem to have problems finding much info regarding tuning/modding the 8HP Briggs :mad2:
88nightrider
That is really strange considering everyone owns one.......:sarcasm:....:lolgoku:
:funnypost:
I know the 5HP is more popular. But is the 8HP "rare" or just too heavy?
Why is it not used more?
Only place I can see that they moding them is in lawn tractors. But they are generally only vertical engines. So oiling mods and such would not be the same :(
solomon
ca
IMHO the 8hp block is much better built than the 5Hp. Its all around stronger from what I can see. I can only imagine the power one of theses engines would produce at 7-10K RPM.
solomon
ca
I would run it. Are you gonna build up an 8hp? I wouldn't run it over 5k rpm. You would want to buy a tachometer to know what rpms your actually turning. Those motors are REALLY woken up with an aftermarket carburetor. Keep in mind you cannot get a billet rod for it. And these have HEAVY valve springs so im not sure if the motor will "float" before the rod breaks.
88nightrider
I'm thinking about building up THAT engine :D
I think I have a tach on an old moped that I can use (hoping water has not gotten into it...).
You don't happen to know the length of the stock rod? :D
When I get the engine here (might be a month) I plan on starting a thread on it ;)
solomon
ca
I do not know the length offhand. But i can probably get it today. I have some custom parts if your interested.....
I am currently doing something similar. 8hp Briggs build. I currently have the motor completely torn down. Shaving eyebrows, port and polish, remove governor, etc.... Been spending more time cleaning and trying to polish the block, head and side cover then anything else!! Lol
solomon
ca
I have an intake and carb sitting here for sale. Most any carb will work great on this motor, because they came with a horrible updraft carburetor which has horrible throttle response and never run right and once off-road they run even worse due to the poor float design. Interested in a milled head?
