To fix or put on a go kart?
shakey0818
Just picked up this tiller for $25.My friwnd said it was running last year.I put some gas in it and it immediately started leaking from the bowl where there is a piece of flat stock and a few nuts.I didn't get into it much other than trying to start it.It seems to want to run.Hopefully I will get it going and use it on my yard.@It has some kind of and is a 8hp.I am wondering if maybe I should put it on a on my manco with a torque converter. TTACH]47863[/ATTACH]
Sent from my SAMSUNG-SGH-I527 using Tapatalk
2SlickNick
American Minibikes @ FB
Mesa, AZ.
View attachment 47864View attachment 47865
Heck ya!!! Bigger is always better in terms of torque. I say:bannana:
Felineman
Death by misfortune
Muskoka Lakes,Ont
Keep in mind some of those engines are meant to run slow and long, Running an industrial engine at top rpm will cause them to EXPLODE. Harbour Frieght has good engines for karts on sale right now for $100.
a well maintained B&S is much better than any predator.
Just think of it this way:
There are 40 year old B&S flatheads on karts out there.
I bet you wont say that about a predator in 30 years ;)
So I'd say: yes, mount it on your kart.. check the shaft size (straight 3/4" or 1") and get a comet series 30 (Tav2 Kit) TC.
that is about the biggest engine it can handle, but it can:D
Leave the governor where it is, and you wont have to worry about running it full speed all day ;)
If you think about removing the governor, then make sure to check each and every bearing, bushing, seal and while you're at it the rest of the internals (conrod, crankshaft, cam etc.) ;)
Kaptain Krunch
Pro Junk Collector
vermont
Actually, a harbor freight clone is just that, an industrial engine. They are designed to run within their governed RPM range (generally 1500-3600rpm give or take), as long as you want them too. A tiller engine will handle 3600rpm all day no differently than a harbor freight clone. If the governor is removed and the engine ran past its designed rpm, then yes there is a chance it will fail, however i would argue the clone has a better chance due to poor quality control.
exenos
Project Nut
Just ask Fowler about the small industrial engines like these. I'd be willing to bet that he has one or two on the farm that have ran almost 24/7@3600 rpm for years now. It's what they are designed to do.
EDIT: A little bit of topic but still relevant, it drives me nuts when people think that running an engine in its top rpm range will kill it. As Kaptain Krunch said, engines are designed to operate in their specified RPM range and they will do so without complaint for far longer than most think. I've made entire road trips in 3rd@4100rpm with my truck (4cyl + truck = underpowered) and no harm was done. While it may have not been directly designed to do that it is still well within the safety margin that the engineers set.
Just so I'm on topic :D Does that engine have a 1" shaft?
shakey0818
I dont know what it has yet.Will let you all know more when i get the time to check it out.Tnx for the replies.
I agree completely. The only thing that will reduce lifespan or blow it up is if you run it at RPM's it wasn't designed for without upgrading other stuff
