Starter Recoil
MikeWidd
Southeastern Pa.
I was trying to start my sons Kart today. I pulled the rope and I heard some Brushing/Grinding. The rope did not return so I removed the shroud. The rope didn't break but there is a thin band on the other side of the plastic disk. When I pulled it out it looks like the band spun. Can this be put back together or is it toast?
Its a 3.5 Briggs & Stratton engine model # 136212 0006 01
Felineman
Death by misfortune
Muskoka Lakes,Ont
If its in good shape it can be but its the worst job you can think of and quite dangerous. Better to spend the money and get a new one.
MikeWidd
Southeastern Pa.
Then I'll pose this question to you guys. A new recoil is $35.
Should I just head to Harbor Freight and pick up a Predator, they are on SALE for $99??????
porsche930dude
Upstate, NY
it can be fixed and its not that hard. all in the technique . make sure the ends are good good and that they will grab into their spaces. you may have to grind new notches on the spring if the end broke off of yours. Untie the rope and set it aside. put the coil and spring back in. Then wind it up so it has tension and put the rope in. Alot of people try to assemble it with the spring winded up already and thats when things go bad. But by all means a predator is a whole different animal than a worn out old 3.5 briggs. if your boy is getting bigger and has enough experience to handle more power its a good upgrade.
88nightrider
Norway, Sandnessjoen
Well you get a new engine then. And with some form of warranty I guess!?
I would say that its is up to you
Then you can send me the old one :stir:
