Series 40 driven sheave question
zr1john
Kentucky
Hello,
i have old Klipper yard kart that I have put an 11hp clone engine on. I have purchased a 40 series torque converter set up to put on it. I know the 40 series driven sheave should be mounted with the spring side inboard. However my set up does not allow this and I need to mount it with the spring to the outboard side.
I have ordered the reverse wound spring (yellow) and I need to know if the purpose that this spring is made so I can run the driven sheave with the spring side outboard.
Thank You,
John
Hello,
Thank You,
John
That is correct, yes
zr1john
Kentucky
Thank You,
I just wasn't sure. I would have to remake the whole back half of the kart if I couldn't have made the driven sheave run outboard.
