Guide me to replace head gasket.
nick956
Harlingen,Tx
Okay so I tighten bolts on the head. No luck. Oil still leaking from the side. I need your help on how to replace the head gasket on my 90 cc Baja atv engine. PLEASE help is Very much appreciated
fowler
Bullsbrook West Aus
Did u torque the bolts up
Basic steps
Time engine
Remove timing gear
Remove head
Clean surface with flat block, entry cloth and CRC
Install new gasket
Install head as per oem specs
Reinstall timing gear
Retime engine
Your good to go
We need the exact engine to give more detail
88nightrider
Norway, Sandnessjoen
I'm guessing its the engine from this thread Baja 90 gasket leaks
zbuck
Ft. Wayne, IN
:wai:All good advice, but I suggest that you get a manual for that engine, that way you will have the timming and torque specs. With 4 head bolts torque in a X pattern.
Half-breeder
"Edit" button removed
... not sure the 'reason' youre replacing the gasket... but if it leaks... and if the torque on the bolts/nuts are correct... it tends to make me think your head may be warped, and needs to be milled... just my thought on this.
bigrusty
springtown tx
gy6 engine smokes
just re did top end (rings.valves -springs -seals)was smoking very bad ran perfect for 4 hours no smoke -next day started smoking like b4 when going up hill- no smoke on level ground or down hill ???:mad2: HELP PLEASE GY6 150cc engine in twister Z150 go kart
Half-breeder
... well bigrusty, just wondering... did you breakin the motor to let the rings conform to the cylinder? Also... did you change the oil again after the breakin period? IMO, if neither of those things were done... you 'may' have just fried your rings and 'may' have to redo em... just something ive been told(not willing to 'test' the theory... so Im not 100% sure). Also, make sure youre using the proper viscosity oil. Thin/bad oil tends to pass by rings and cause smoking.
Also... bigrusty, start your own thread on your question(s) n plz dont hijack this/someone elses thread... ty.
