Baja 90 gasket leaks
nick956
Harlingen,Tx
Hey guys so this thread is centering around the valve gaskets of my brothers 90 cc Baja atv. The gaskets seep oil around the cover and I can actually see little bubbles pop around theft side gasket. Now im asking, can I take apart the cover , remove the original factory gaskets and apply permatex RTV high temp gasket maker? It's not leaking major but enough to see oil dark ring around the gasket.
Sent from my SPH-L710 using Tapatalk
88nightrider
Norway, Sandnessjoen
Aint that the headgasket???
Try to tighten the head studs. See if they've come loose a little.....
If its the headgasket I would second this
firemanjim
Just kartin' around....
Houston Texas
Tighten the bolts. That's your head, not valve cover. The reason you see bubbles is cause its under pressure from the engine cycling and building up internal pressures that normally are released by an open pressure relief valve , towards the back of the case.
Yes you can replace the sight glass. But your gonna have to open the case, IIRC.....
nick956
Harlingen,Tx
Is there such a thing as two seperate fluids that go into my motor? Like transmission fluid and regular oil? Also how do I remove the head from engine? All I see is the four bolts in front
firemanjim
Houston Texas
that's all there is.... 4 bolts. that's why you should try to tighten them first. it don't take much to make one loosen up, at least from my experience with the clones... it only has motor oil in it. They use a wet clutch system where the clutch is bathed in engine oil, as its running. When replacing the clutch plates, you must first soak them in fresh engine oil for 12-24 hours, or they will just glaze up and burn.....
