Off to get some parts at NAPA?
ohsoblue92
Doing a little preventative maint on the little dudes cart. (Manco 415 two seater). Needs a new drive chain and wheel bearings. I'm pretty sure NAPA has the #35 roll chain but I'm going ot see if they happen to have the wheel bearings as well. I found them on line for $3.50 a piece but I would rather not pay for shipping........ Has anyone had any luck sourceing wheel bearings at a NAPA? Guess I will find out after work:thumbsup:
You can get the wheel bearings for about a buck or two online and the chain for $2 a foot.....You only need 3'.....
Tractor Supply should have the chain - but you have to buy 10'. They might also have the wheel bearings- soooooooo......you just have to weigh the difference in time between waiting for them at your door- or the cost of time traveling to get them and fuel and paying more than you need to. .......
KartFab
I found some once at an ace hardware. Maybe a big local (not Home Depot or lowes) hardware store might have one as well.
jandj
Williamsburg, Va
If you have a part number or measurements and your NAPA employee is worth a ****, they can get them. If your NAPA is one of the halfass ones, forget it. Luckily my local NAPA is one of the good ones.
ohsoblue92
Thank you everyone.... Here's what I found out. Got ten feet of chain and cut off enough to make one for the cart. I saved the rest cause I'm pretty sure this isn't the last chain the little dude will go thru. NAPA also had the wheel bearings P/N 7-04294. They cost a little more than the ones online but I was told that they will last longer. I guess that part is yet to be seen being as they were made in China too.....:mad: Anyway he's back to tearing up the grass at a feverish pace.... Thanks again everyone.....
That's all that counts....I'm sure you paid double.....but you can't put a price on their happiness. ...just don't spoil them too much....you'll put granpa out of a job.......
