250 pausing while starting
jman231994
Australia
Hey guys, I've been having some issues with the engine for my buggy, been trying to get it running and being electric start only I've obviously needed that to work....
Initially it would do about half a crank then stop and take a lot of trying to get it to turn again...that turned out to be some oddly shaped teeth on the ring gear jamming up. I fixed that but now it seems to be absolutely gutless on the compression stroke while it cranks. It's not the battery, just tested it while I cranked it, held 13.6v the whole time
Here's a video, mostly for the sound so you understand what I'm getting at
...or not, I'll have to host that somewhere else by the look of it, I'll get to that soon. In the meantime if anyone understands what I'm getting at please help :) haha
Thanks
solomon
ca
Have you checked and cleaned all terminals and connections? Have a solid ground? How are the battery posts and terminals?
jman231994
Australia
Currently just running with jumper leads, battery terminals are good, not sure about the ground, it's on probably the cleanest part of the engine so shouldn't be too bad
EDIT: Just rewired it using nice thick cables and still exactly the same, video will be up in a sec
if it's not a weak battery, maybe the jumper cables are not connecting very well
or one of them is broken.
In any case that sounds like there's not enough current flowing.
Or the starter brushes are worn out (I doubt that to be honest.. but it's still possible)
Only other thing would be a seized engine that the starter hasn't enough power to rev.
So, remove the spark plug, try to start it and listen for "noise",
check your oil level and try again (with plug ;))
jman231994
Australia
Yep, its now hooked up with short thick cables, nothing wrong there
Brushes are fine, I took the starter apart a few days ago and all were in pretty good shape
Engine turns over perfectly by hand with the side cover off, so certainly not seized, does feel like it has a lot of compression though
I haven't given it a go with the plug out since I cleaned up the ring gear though so might give that a shot tomorrow
The most annoying thing is that in that period where it pauses there isnt any noise whatsoever, the piston doesnt appear to be moving at all, so it must complete a cycle before it stops :(
I might just get to a point where ill start looking for a new engine, I can pick up another engine from the scrapyard for less than a new starter for this thing haha
Thanks for the help, keep the ideas coming haha
zbuck
Ft. Wayne, IN
:wai: Take that starter off and bench test it. It sounds like it is not engaging into the flywheel. Another thing you can try, using your jumper cables, attach the ground cable directly to the starter and then touch the postive cable to the starter postive lug and see if engine will spin, do this with the spark plug removed and a rag over the plug hole. When doing this, you will have sparks so have nothing combustible in the area.
jman231994
Australia
Thanks but it's actually always engaged, the ring gear on the flywheel is on a freewheeling hub, so if the starter is going faster than the engine it will turn it over
I'll give that a shot, just wondering, what's the rag on the plug hole for? So I guess if it acts the same with the plug out I've likely got a dead spot in the starter yea?
jman231994
Australia
What do you mean by undercut?
And yea no solenoid on this thing haha
Here's a pic for reference, motor is just a normal dc fixed magnet motor, drives a few shafts and gears to get a reduction before the flywheel, and at the flywheel it is always engaged, but on a freewheeling hub so it doesn't spin with the engine
fowler
Bullsbrook West Aus
It will have a soliniod
Follow the wires back
It will be remote mounted
It looks like a giant relay
Which is basically what it is
Under cut
You know how an electric mother works
As the brushes spin on the commutator they obviously push on it with a bit of force ( spring loaded)
Obviously they will wear away the comutator eventually
As they do they sorta drag the copper across the gap
When u look at it u can't see the joint between each bar
This of course results in the Loss of some magnets
Resulting in a loss of torque
Google it
Get a hack saw blade or something and recreate that gap
It's a common thing to do on truck starters
If it's a reduction gear type then ensure there's stil plenty of grease in the box
EDIT
What type of battery are u jumping off
Make sure u get a known goody
Like jumping it from a running car
jman231994
Australia
Under cut
Google it
EDIT
Oh right the starter relay, yea it's working fine as far as I can tell, isn't heating up or anything like that.
And I didn't think to do anything more than clean the commutator so I will give that a look, thanks
And yea seems like a good battery, voltage is stable. It was in my mums car and we thought it was dead but pretty sure the alternator died a few weeks later anyway. And I've also been using the battery I intend to put in the buggy, it seems pretty much perfect, just doesn't have a heap of capacity for testing so I've switched to the car battery. I'll give it a jump off my car anyway just in case
And I've since cranked It over with the spark plug out and it was turning over perfectly, had the valve cover off at the time to check if the oil pumps working too, seems good. Can pretty much confirm with 100% certainty that it's not a valve hitting the piston too which is a relief
fowler
Bullsbrook West Aus
A battery with a collapsed cell will work fine untill u load it
It just can't deliver the currect
They're great for powering low volt
stuff though
Iv got a 1200cca CAT battery I use to power my engle
Your battery is like an accumulator+storage for the electricity
It can take shocks out of the system
When the altinator dies it usually takes the battery with it
Or is caused by the battery
jman231994
Australia
Yea I've checked the voltage of the little battery as it cranks the engine, no voltage drop at all. Big one I haven't done but it cranks it exactly the same so I'm inclined to guess its alright.
Other than that, I took apart the motor again and the commutator gaps were clean and clear, however, I decided to test the continuity and resistance of the coils, all the opposites had continuity as you would expect, however some others had continuity, say for instance one of them and the one to the left of the one opposite it....With very limited knowledge of motors this complex I have no idea if this is normal or if its stuffed....just doesnt seem right to me
zbuck
Ft. Wayne, IN
:wai: Rag over the plug hole, to catch any liquid that might spray out. Question, have you checked the valve settings?
jman231994
Australia
No liquid in it haha havent got that far yet :p It did come in handy for seeing when the pistons coming up though haha, it would blow the rag up
And Yea, said that above haha. Havent actually checked the lash but from what I'm seeing as it turns over the valves are all kicking in at the right, so cant see why it having too much compression would be an issue there. And definitely not hitting the valves
You can do a few thing off hand even if you arent all that familiar with electric motors.
Without a growler you can do a few tests to see is there might be any obvious faults.
You can check to see if all bars are good as in no shorts to ground, By checking bars to the shaft, with a multi-meter set on continuity.
Also you can clean up the bars by undercut the bar gaps, of the mica insulator plates, using a fine tooth hacksaw blade. You can also sharpen it to a point as this helps to pick into the gap and scrap it clean.
Take a look a this thread here on the HAMB. About half way down.
http://www.jalopyjournal.com/forum/showthread.php?t=849222
jman231994
Australia
Haha that's the exact thread I read yesterday when I didn't know what undercutting is.
So, there's no shorts to ground but weird shorts between the commutator plates that undercutting didn't fix...might try doing it again though I'm starting to think the insulations failed in a coil
Most likely not, there would be a burn mark or other signs of that failure.
Might have to take it to a start/alt shop, for them to put it on the growler.
Post a pic or 2 of the armature you have. Maybe there something not too obvious to you.
jman231994
Australia
Sorry pic isn't the best, just what I took last night. I'll get a better one today.
It does look like the insulation has gotten quite hot where it meets the commutator, some of it looks crispy but not like other shorted electrics that I've seen
