...As far the geometry is concerned it has copied exactly from a 115cc TKM extreme chassis kart so how that is wrong, you tell me...
Well first of all, as far as I can see your control arms are at an angle too big to achieve propper Ackermann steering, the kingpin inclination seem to be unequal on the pictures (I don't think it is) but it's at least too little for the way you mounted the front wheels.
your caster needs another two or three degrees at least I'd say to have a good straight running kart,
Well the camber seems to be zero that looks okay, but for spindle arms that long the tilt will be odd when cornering.
(you want the wheels MUCH closer to the kingpin)
If your race kart has that exact same steering geometry,
I owe you a beer.. but I doubt it!
... Yes the engine is on the opposite side to most normal karts but IF IT WAS ON THE OTHER SIDE IT WOULD GO IN REVERSE!! Yes I could turn it around but it'd be even more "unsafe" as you'd run the risk of shredding your arm on the sprocket!!
Well that's why god send us chain and exhaust guards for karts
TKM rules state that the engine
MUST BE at the right hand side btw
I understand and expected to receive a lot of the points mentioned such as bumpers and a floorpan, however the way 'itsid' went about it was wrong. Admittedly I gave the wrong impression initially and asked the wrong question however I don't understand a number of his points as they appear to be drawn from no where. What is the basis of his analysis of the geometry and tube thickness? As I stated earlier it is exactly the same as a competition kart and the tubes are actually slightly thicker.
I can't tell for sure what tube sizes you chose of course by just looking at the pictures.
I can only guesstimate the numbers.
Saying you have a 50mm rear axle (about the biggest dia I know)
that tubes look like ~20-22mm max.
which is way too small for a race kart;
race karts have 28-35mm, based on FIA regulations AFAIR.
those are to be met to get MSA yearbook approval, and that's needed to run TKM class karts btw
And most important it's most likely a better grade steel too
But again, this kart looks short.. very short for an adult kart;
maybe that's the problem Cadets, Bambini and junior karts are not meant to take and carry the weight of an adult of course, thus the tubes can be smaller (as small as 25mm on some karts and classes)
Anyways...
You've come to the right place,
this forum can
and will provide all the help you need to make your idea not only safer but also better handling, and if you want faster too
But you need to uncross your arms and listen sometimes
PS Sorry for being harsh, I didn't meant to
