Hi, my name is Chris. I am a hardcore car guy, mainly of the bmw types(mostly e30's for you car guys), But am lost when it comes to this engine. I want to use it for some kind of fun project, that I can play with to make more power.
Here is my problem, I Know nothing about these flathead briggs, or briggs engines at all to be honest. So I cam here with a few questions, but first here is what I know about the engine.
Model 130292 type 0709-01 code 76101307
13 cubic inches
series 0
horizontal shaft, with another aux shaft off the cam( which is really my main concern)
9 plain bearings
2 rewind starter.
So I am curious about a couple things.
What is going on with the aux shaft that seems to be off the cam? I say seems because I have not ripped it down to check it out yet. Can I still use this on a cart? If not can I get away with another cam and just welding the hole up?
Second question:
Are the plain bearings going to cause me any problems when trying to get as much horsepower out of it? When I mean as much power I mean as much as I can get out of it without spending a ton of money as this is a for fun project. I know that if I want to spin over 5k I need to replace the rod and possibly flywheel.
Third question: cams
I was looking around on youtube and I have watched a few videos where people did there own welding and griding on the cams that looked fairly crude. Can anyone enlighten me to how they get away with them being kind of crude? I am also curious to what cam I should look at getting? more on the goals though later.
fourth question:
is the carb on this thing worth anything? and if not where can I get some good information on go kart induction?
Goals
I am trying to build a fun engine just to see what I can do. I have access to a decent amount of resources and I am very good with anything mechanical.
So id pretty much just like to make the most power I can for as little as I can. Things that I was looking into doing.
Shaving the head .030 or more?
getting heavy duty springs or 2 exhaust springs?
a cam, or make my own grind if I can get some more info.
shave the hump in between the valves.
some kind of induction work
porting
gov removal
flywheel maybe?
What else should I look into doing?
Either way thanks in advance for any help!
13 cubic inches
series 0
9 plain bearings
2 rewind starter.
Second question:
fourth question:
Goals
porting
gov removal
flywheel maybe?
