Tomberlin engine swap
Blitzcraig
I have a Tomberlin Crossfire 150R that I picked up at auction. The engine had problems so I saw the GY6 on eBay fairly cheap so I thought I would just buy a new one and swap them out. I got the engine then realized the case was different from the original because the original has a built in reverse transmission. My question is can I make this new GY6 work by buying an external reverse and putting it on the output shaft? Those original Tomberlin Howhit engines seem impossible to find. I didn't know that much about these go karts until I tried to swap the engines today. Any help would be greatly appreciated.
Blitzcraig
Well, the engine had been tinkered with before. Some bolts missing and broke in the engine cover, wouldn't start, oil looked like water. I don't know how to rebuild one so I ordered a new GY6 from eBay and now I'm trying to figure out how to make it work. If the sproket on the external reverse will line up with the axel attorney then it shouldn't be a problem but if it doesn't then I'm out another $140 with no luck.
Blitzcraig
That's another problem, I checked eBay after I saw the difference in engines and the seller had it listed as "no returns". Another lesson learned from eBay buying. I foolishly assumed it could be returned when I bought it since it is new. I also saw those engines you have pointed out. Do you think the shifter can be relocated between the seats like the original?
I haven't seen your engine yet...
but yes I'm pretty sure you can just remove the shifter lever and attach yours.
Blitzcraig
Ok, here's my options;
1.) Buy an external reverse for the new engine. But it May not line up with the sprocket on the axel.
2.) Disassemble the old engine and use the old case with the new parts from the new engine which would definitely line up.
3.) Buy a rebuild kit for the old engine and try to sell the new engine and get some of my money back.
KartFab
I have the same kart I bought (150r). Engine is toast but looks complete. Has some sort of reverse gear etc. I'm going to be getting rid (selling) of all of that engine/reverse stuff. I'm busy now but will have time to post pics tonight. If you need any parts (engine related)just let me know.
Blitzcraig
Thanks gran. I might be interested in the whole engine depending on condition, price, and shipping costs.
